Syvecs Pops and bangs map
T2 MSW
Bit of an odd one. Changed the vehicle speed to 0. Watched the map on the laptop whilst blipping the throttle and it goes into the range where it should do something, but nothing.
Then change the 1000 -1500 fuel cut in ALS cal2 to 50 percent and its doesn't work, engine runs perfectly.
Finally change the ALS cal 1 to exactly the same settings as cal 2. Then change cal Switch to use ALS cal 1 and it works as expected.
Why does ALS cal 2 not do anything??
edit to say that pops and bangs is mint though - thats going to be some fun in tunnels :D
It sounded like it had a very bad missfire. Might have to try it again for when we have the go pro on :D
depends on what or how they have mapped your pops and bangs , the map part that is affected is only your vacuum area so should not cause any misfires when driving normally , only when you lift off the throttle .
when you say missfire do you mean it popped and banged :D
Edited by mellonman (see edit history)
We was only poodling through Southend, so doubt we had enough speed to make it work.
You just need to get someone to turn it up abut more :D got my car back recently and my pops and bangs was more pops and burbles no bangs, got Ryan G to turn it up a bit now there's some pretty big bangs and flames lol
I did ask him to get pops ands bangs when hitting the limiter but it seems like I have no luck with that one :(
It wont work while driving its meant to be for a launch control..
Vid of mine on my youtube channel (notice how it comes out the twin screamers at the front hehe :cool:)
Thats launch control / 2 step, not a pops and bang overrun fun map :D
Sent the e-mail guys
Yeah I also would like this but was advised it wouldn't be very healthy doing so :(
:D
Did you keep the settings the same from the map that was emailed over?
Yeah Paul's is the same as mine. Only things needed are as below.
CAL that turns on ALS set to ALS calibration 1.
ALS cal 1 fuel cut at below 4% throttle
ALS cal1 ing retard below 4% throttle.
Edited by T2 MSW (see edit history)
Email coming your way Wez :)
Hey Matey,
Just seen this and had a quick look at your map, cal switch 6 is using antilag CAL1 which looks to be setup like overrun bops and bangs, vehicle bypass speed is 10kph but noticed that it is globally disabled, might be worth running by Ryan to see if you can enable it.
