bdh1987 Posted May 10, 2015 Share Posted May 10, 2015 Hi guys, Are there any better than OEM oil pumps or is OEM the one to get? When the engine starts, oil pours out like mad from where the oil pump is so I'm guessing I need a new one, is there anything else I need or would it just be that? Cheers, Ben Quote Link to comment Share on other sites More sharing options...
Benjy Posted May 10, 2015 Share Posted May 10, 2015 Could be the front main oil seal. Quite common. But if you ended up needing a pump, OEM is perfectly capable. Quote Link to comment Share on other sites More sharing options...
