Tuscan Posted August 21, 2015 Share Posted August 21, 2015 I want the steering rack. I've Pm'd you Link to comment Share on other sites More sharing options...
monkey3 Posted August 22, 2015 Author Share Posted August 22, 2015 I want the steering rack. I've Pm'd you ...and replied. Link to comment Share on other sites More sharing options...
Slink116 Posted August 23, 2015 Share Posted August 23, 2015 alright mate, I would like to buy the centre console/armrest of you, Pm me please Link to comment Share on other sites More sharing options...
Guest Wishbone Posted October 1, 2015 Share Posted October 1, 2015 Hi Do you still have the wishbone, left hand side upper, and is the bushing OK Thanks Pete Hi, I've got a ton of parts left over from breaking my late-96 facelift TT6. These are the only parts I'm selling in this thread so please don't ask for any others. Please keep all replies in the thread as it's a real pain to keep track of messages, who wants what and who got there first. Prices do not include delivery but I should be able to send small items for about £6-8 by courier (less for very small items), I can give a proper postage quote once I know what you want. Large items can be shipped but I'd prefer they're collected as it will be costly. Thanks. [table=width: 500]Image Item No. Item Desc. Price Buyer Status 1.jpg 1 nsr suspension arm £30 1.jpg 2 nsr wishbone £80 1.jpg 3 osr wishbone £80 1.jpg 4 front wishbone £40 1.jpg 5 front wishbone £40 1.jpg 6 front crossmember arm??? £5 1.jpg 7 front crossmember arm??? £5 1.jpg 8 osf hub £45 T2 MSW Sent 1.jpg 9 nsf hub £45 T2 MSW Sent 12.jpg / 13.jpg 1 osf wishbone (needs remainder of bolt pressing out) £50 ellis Paid. Collected by 214supra 12.jpg 2 nsf wishbone £50 ellis Paid. Collected by 214supra 2.jpg 1 nsr suspension arm £25 2.jpg 2 ??? £3 LOGIE Sent 2.jpg 3 ??? £3 LOGIE Sent 3.jpg 1 spare wheel clamp £5 3.jpg 2 brake pedal bracket and switch £10 3.jpg 3 ABS pump £70 3.jpg 4 Steering column with 1 key £40 3.jpg 5 Front tow eye + 3x bolts £10 3.jpg 6 Front tow eye + 2x bolts £10 4.jpg 1 space saver spare wheel (never used) £15 4.jpg 2 dashboard bracket £3 4.jpg 3 dashboard bracket £5 4.jpg 4 rear wheel arch vents £5 4.jpg 5 rear exhaust heat shield £5 5.jpg 1 centre console / arm rest £35 5.jpg 2 passenger foot rest £5 5.jpg 3 lower dash panel (note the small hole behind the vent - this contained a switch and is not visible once the panel is fitted) £5 mc92 Sent 5.jpg 4 facelift clocks dash panel £17 5.jpg 5 facelift rhs dash panel (some swinging key scuffs under the ignition barrel - small fog light switch) £10 kitch79 Sent 5.jpg 6 facelift top dash panel £17 turbo-V8-turbos Sent 5.jpg 7 rear wiper arm (newish toyota blade) £7 5.jpg 8 osf wiper arm (newish toyota blade) £7 5.jpg 9 nsf wiper arm (newish toyota blade) £7 6.jpg 1 ABS ecu (89541-14060) £20 6.jpg 2 Rad fan relay / abs (trac) relay (85925-20010 / 88263-35070) £10 6.jpg 3 A/C Amplifier ECU (88650-14272) £20 6.jpg 4 - - - SOLD 6.jpg 5 ??? £10 6.jpg 6 bulb failure ecu £10 6.jpg 7 Power steering ecu (89650-14093) £10 6.jpg 8 Fuel pump control (89570-14240) £10 6.jpg 9 Door control ECU (85980-14070) £10 JayJay1374 Sent 6.jpg 10 Antenna relay (85914-33010) £5 6.jpg 11 rear number plate lighting unit £10 Jordanmol Sent 6.jpg 12 horn £5 6.jpg 13 nsr running light £10 6.jpg 14 radiator clamps £5 Carbon_Bullet Sent 6.jpg 15 front dash tweeters £5 6.jpg 16 cabin temp sensor? £3 6.jpg 17 heater controls (blue led conversion by Heckler) £35 DodgyRog Paid. Collected by 214supra 6.jpg 18 traction control controls (blue led conversion by Heckler - slight scratch across one of the buttons) £10 6.jpg 19 drivers window controls (blue led conversion by Heckler) £15 DodgyRog Paid. Collected by 214supra 6.jpg 20 cigarette lighter - not used(blue led conversion by Heckler) £5 DodgyRog Paid. Collected by 214supra 6.jpg 21 passenger window controls £10 6.jpg 22 rear window wiper motor £25 6.jpg 23 climate control glare sensor £3 7.jpg 1 steering column stalks / electronics / for airbag £30 7.jpg 2 bonnet clamps with cables £10 Carbon_Bullet Sent 7.jpg 3 bonnet pull with cable £10 Carbon_Bullet Sent 7.jpg 4 boot pull cable £5 7.jpg 5 horn £5 7.jpg 6 pedal covers (clamp on - no need to drill) £5 7.jpg 7 accelerator pedal (hardly worn at all) £10 7.jpg 8 plastic cover??? £2 7.jpg 9 metal cover??? £3 7.jpg 10 metal bracket??? £5 7.jpg 11 assorted metal brackets £3 7.jpg 12 metal bracket £2 7.jpg 13 air intake (from over the radiator) £10 7.jpg 14 metal heat shield??? £3 8.jpg 1 starter motor £45 8.jpg 2 air intake pipe + Apexi induction kit £15 Marty Sent 8.jpg 3 carbon canister £12 8.jpg 4 osr hub (including nearly new bearing) £45 T2 MSW Sent 8.jpg 5 nsr hub £45 T2 MSW Sent 9.jpg 1 petrol tank (including neck stuff, cap, pump cover) £10 LOGIE Sent 9.jpg 2 petrol tank under shield £15 gdog1989 Paid. Collected by 214supra 10.jpg 1 fuse box / lunchbox £10 10.jpg 2 centre exhaust heat shield £5 11.jpg 1 nsf??? inner arch £7 Jordanmol Sent 11.jpg 2 osf??? inner arch £7 Jordanmol Sent 11.jpg 3 front bumper bar £20 Keron Sent 14.jpg - Front ally subframe £15 22.jpg - Front subframe £20 15.jpg - front wiper motor with fixings £25 16.jpg - steering rack £40 17.jpg - aircon radiator £40 214supra Paid. Collected by 214supra 18.jpg / 19.jpg - Advan racing front wheel powder coated black, not kerbed - plus part worn front tyre goodyear eagle f1 - 235 40 18 (1 rear wheel also available) £50 Shane Collected 20.jpg - roof lining (immaculate condition - with light and fixings) £80 - - bonnet - this needs to go asap - small dents, no creases (should press out) where it was walked on at the recoverer's £40 21.jpg - screen washer bottle and pump £25 [/table] Link to comment Share on other sites More sharing options...
monkey3 Posted October 2, 2015 Author Share Posted October 2, 2015 Hi Do you still have the wishbone, left hand side upper, and is the bushing OK Thanks Pete Yes and yes. It's item 4 or 5 on picture 1, right? Also, any idea how to tell the difference between OS and ns? Link to comment Share on other sites More sharing options...
QPRSupra Posted October 5, 2015 Share Posted October 5, 2015 Hi, is the steering rack still available? How much would you do this for posted? Is it tight with no play in it when on the car? Cheers Link to comment Share on other sites More sharing options...
monkey3 Posted October 15, 2015 Author Share Posted October 15, 2015 Hi, is the steering rack still available? How much would you do this for posted? Is it tight with no play in it when on the car? Cheers No sorry, it went a little while ago. And it was tight, very tight. Link to comment Share on other sites More sharing options...
and1c Posted October 16, 2015 Share Posted October 16, 2015 No sorry, it went a little while ago. And it was tight, very tight. Have you got an original front bumper by any chance? Link to comment Share on other sites More sharing options...
monkey3 Posted October 16, 2015 Author Share Posted October 16, 2015 Nope, only the stuff in the list at the beginning and at the other link in my signature. Sorry. Link to comment Share on other sites More sharing options...
