firin Supra Posted May 10, 2015 Share Posted May 10, 2015 Hi peoples just woundering would the auto gearbox fit the supra also could the tiptronic adapt in the uk supra or if not what would i need etc any help would be appreciated thanks Quote Link to comment Share on other sites More sharing options...
chrispot Posted May 12, 2015 Share Posted May 12, 2015 you would need the ecu and plugs for ecu as well as the gearbox, don't know if box would fit. what engine is fitted to said vehicle? may need prop to be altered and load of other stuff. i would say don't bother. i have a tiptronic box and may be once or twice a year use the tip. Quote Link to comment Share on other sites More sharing options...
garethr Posted May 12, 2015 Share Posted May 12, 2015 The IS gearbox would bolt up to the Supra engine, but you'd have to wire up the IS ECU to control the gearbox and the Supra ECU to control everything else. Even if you could make it work, the A650 from the IS is weaker than the (TT) A340, and would probably be at or beyond its limit with the standard 326bhp. Quote Link to comment Share on other sites More sharing options...
