msupra1 Posted May 8, 2015 Share Posted May 8, 2015 My current coilovers are very soft, and I am having rubbing issues with my aggressive wheel setup, so I had to change to this alignment: -2.2 camber front and rear, front caster is set at 4.0 and toe is 0. I found these specs on the AU Supraforums. From my understanding it was a street/track setup. Needless to say, I was getting significant tire wear. I just picked up new tires and I'm trading suspensions with a friend to hks hipermax. So I'm able to dial back my camber as I shouldn't be rubbing on the fenders. Just wanted to check If everyone is using this alignment or have some of you played with the settings a bit more? I was thinking about adding some more camber in the front, like -1.5 but not sure if that's going to give me uneven tire wear. Lance Alignment: Front: Camber - 1.0 degrees Caster + 5.0 degrees Toe 0.00 mm Rear: Camber -1.5 degrees Toe in (total) 1.00 mm Quote Link to comment Share on other sites More sharing options...
