T14PPA Posted May 7, 2015 Share Posted May 7, 2015 Im looking at buying another turbo and was wondering how to store the other one to not cause any damage or force me to rebuild it if i use it in the future? Quote Link to comment Share on other sites More sharing options...
chrispot Posted May 8, 2015 Share Posted May 8, 2015 what i would do is pour a drop of gear oil into feed/drain then if poss fit plugs to cap off, then put in a cardboard box with some silica gel packs. but try to store it in a place where the temperature does not change that much. because what can happen is, say it's stored in a shed and it's been a very cold night the turbo temperature would also be low, then the sun comes up and warms the shed and the temperature can change very quickly. as you know warm air can hold more moisture than cold and this warm air can hit the turbo which is still cold and condense and moisture can form on it and may start rusting it. toolstation sell a can of protective wax spray. but i would not spray the inside of the compressor or turbine, as you don't won't any dirt etc sticking to wax. wait until the misses has gone out, then store in under the bed if possibly ( assuming your not incontinent, as that could rust it quite quick) other tips would be, don't use it as a door stop or a paperweight? both would look cool regards chris. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 8, 2015 Share Posted May 8, 2015 Engine oil in the ports of the centre section, then stick it in a zip top plastic bag and put it somewhere dry. I wouldn't bother taking other precautions, they are pretty tough! Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 8, 2015 Author Share Posted May 8, 2015 My plan was to put it under my bed lol like every other car part i buy. If the mrs dont like it then she can do one lool. But thank you both for the heads up. Appreciate it Quote Link to comment Share on other sites More sharing options...
