jza800 Posted May 6, 2015 Share Posted May 6, 2015 I just have to get some inputs here.. dont now if i have a oil pressure gauge problem or something wrong somewhere.. on cold start up i have 80 psi off oil pressure, thats sounds good and normal.. on hot engine i idle about 17 to 21 psi off oil pressure, at cruise i have 47 to 50 psi at 2000 rpms, so long so good, thats seems all fine, but here is my little concern.. when i step on it, the oil pressure stops at 70 psi, even if i only are on 4000 rpm, and it stayes there, even if i goes to 5000rpm or 6000 rpm, so my question is, when does the relief valve open ?? and does the symtoms sounds normal , or do i have a worn gauge??? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 7, 2015 Share Posted May 7, 2015 (edited) All sounds fine, the oil pressure relief valve is holding maximum pressure at a sensible figure. That's what it's for. http://www.waybuilder.net/sweethaven/MechTech/Automotive01/default.asp?unNum=5&lesNum=3&modNum=6 Edited May 7, 2015 by Chris Wilson (see edit history) Quote Link to comment Share on other sites More sharing options...
