bebby Posted May 5, 2015 Share Posted May 5, 2015 Any have any advice on what brake fluid to go for, I'm after dot 5 because I managed to boil Mine at the weekend and pretty much lost all feel So gurus amongst you I ask best option? Many thanks Quote Link to comment Share on other sites More sharing options...
Ric Posted May 5, 2015 Share Posted May 5, 2015 Toyota 5.1 is recommended and is cheap enough, makes sense to use that. Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 5, 2015 Share Posted May 5, 2015 (edited) How old is your brake fluid ? Brake fluid attracts moisture over the years hence it boils when it gets hot and you lose brake performance. DOT 5 is Silicon based and won't mix with DOT 3,4 or 5.1 and might cause problems to seals etc in a Glycol designed system. Use DOT 5.1, it's Glycol based which is what your system was designed to use. Completely replace your old fluid by bleeding the whole system, i use a vacuum bleeder which works a treat. If you want to spend more money then have a look at Motuls RBF 600 or 660 MOTUL RBF 600 and 660 (DOT4) has better dry and wet boiling points than normal DOT 4 and DOT 5.1 https://www.motul.com/system/product_descriptions/technical_data_sheets/168/original/RBF_600_Factory_Line_%28GB%29.pdf?1340122148 https://www.motul.com/system/product_descriptions/technical_data_sheets/169/original/RBF_660_Factory_Line_%28GB%29.pdf?1340124817 Edited May 5, 2015 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
bignum Posted May 5, 2015 Share Posted May 5, 2015 Castrol srf race fluid is the best but its 30 quid a litre so unless you track your car alot that may be overkill, Ive been using brembo 600 and it seems ok, as dunk said motul 600/660 is also excellent. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 5, 2015 Share Posted May 5, 2015 If you really did boil your fluid you would have found the pedal just went right to the floor and you would have ZERO brake retardation. Sounds much more like pad fade to me. Quote Link to comment Share on other sites More sharing options...
