Brake fluid?
bebby
Any have any advice on what brake fluid to go for, I'm after dot 5 because I managed to boil Mine at the weekend and pretty much lost all feel
So gurus amongst you I ask best option?
Many thanks
How old is your brake fluid ?
Brake fluid attracts moisture over the years
hence it boils when it gets hot and you lose brake performance.
DOT 5 is Silicon based and won't mix with DOT 3,4 or 5.1 and might cause problems
to seals etc in a Glycol designed system.
Use DOT 5.1, it's Glycol based which is what your system was designed to use.
Completely replace your old fluid by bleeding the whole system, i use a vacuum
bleeder which works a treat.
If you want to spend more money then have a look at Motuls RBF 600 or 660
MOTUL RBF 600 and 660 (DOT4) has better dry and wet boiling points than normal
DOT 4 and DOT 5.1
https://www.motul.com/system/product_descriptions/technical_data_sheets/168/original/RBF_600_Factory_Line_%28GB%29.pdf?1340122148
https://www.motul.com/system/product_descriptions/technical_data_sheets/169/original/RBF_660_Factory_Line_%28GB%29.pdf?1340124817
Castrol srf race fluid is the best but its 30 quid a litre so unless you track your car alot that may be overkill,
Ive been using brembo 600 and it seems ok, as dunk said motul 600/660 is also excellent.
