JackyBoi Posted May 3, 2015 Share Posted May 3, 2015 This might be a daft question (I've asked my fair share) but I was wondering if there is a way you can wire up a DVD player or even a hard drive to play films, episodes etc on a double din headunit? I've seen it done before but I'm not much good when it comes to electrics - if it helps I have a Pioneer SPH-DA110 cheers guys Quote Link to comment Share on other sites More sharing options...
Virus Posted May 3, 2015 Share Posted May 3, 2015 Should be pretty easy to do. Get a little hard drive (or a USB flash drive) & hook it up to the USB output, It should show up into your radio as normal external media. Then select the video file & it should work. Now i'm not to sure what format the files should be in in order to play them, i'll take a look tomorrow if no one hasen't found the answer tomorrow http://docs.pioneer.eu/Manuals/SPH_DA110_CWW6110_manual/ ^heres a link to the manual in english btw Cheers Quote Link to comment Share on other sites More sharing options...
Scott Posted May 3, 2015 Share Posted May 3, 2015 That headunit is designed to be used with your mobile, but I guess it's pretty straight forward to use with a HDD too. Get yourself a portable 2.5" drive, fill it with stuff, plug it in and give it a go. I recently got this headunit and I plan to install ARUnchained onto my phone so that I can use anything, netflix included If you mirror your phone, you can play just about anything you like through the screen. Quote Link to comment Share on other sites More sharing options...
