binfieldx Posted May 2, 2015 Share Posted May 2, 2015 Hi, I've been advised my import already has a double decat installed, dangerously it runs 1.5bar boost in gear 3 which obviously is quite bad. The company it's with think it might be because the decats don't have any restrictor rings in, does that sound about right? Tom Quote Link to comment Share on other sites More sharing options...
tony tt Posted May 2, 2015 Share Posted May 2, 2015 Highly possible. Easy to find out if it has or not. It should be between the two decats in the middle. Quote Link to comment Share on other sites More sharing options...
binfieldx Posted May 2, 2015 Author Share Posted May 2, 2015 Ok thanks dude, thought i'd check whether its most likely to be that or not before I take the pipe off to check! Quote Link to comment Share on other sites More sharing options...
Pudsey Posted May 2, 2015 Share Posted May 2, 2015 You should be able to see it between the joints. Quote Link to comment Share on other sites More sharing options...
