Swampy442 Posted May 2, 2015 Share Posted May 2, 2015 Question for you all, is the cooling on the auto box thermostatically controlled, or is it constantly pumping? Im getting my car back on the road and, while priming the engine and flushing the auto box with fresh fluid, the gearbox didn't pump any fluid out of the cooling lines. The box has been rebuilt so my main concern is theres something wrong with it.... Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 2, 2015 Share Posted May 2, 2015 Unless its inside the gearbox or controlled by the ecu , Being its rebuilt it might just be a matter of letting the oil fill the vaulve body which would take a while then it would pump out, I was amazed how long it took to crank oil to my single turbo through the new empty lines so I would expect the same for the auto box lines, How long was you trying for? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 2, 2015 Share Posted May 2, 2015 It will take a LOT of cranking to prime the auto box and torque converter, fire it up and I expect you will see the cooler line fill nearly immediately. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 2, 2015 Author Share Posted May 2, 2015 I don't want to fire it up dry though, Ill crank it a little more for peace of mind. Thanks for the replies. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 2, 2015 Share Posted May 2, 2015 So long as pump and clutch packs were lubed as it went together, and TC partly filled with ATF before fitting it won't be "dry". Your more likely to burn the starter out than protect the g/box. Fire the devil up Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 2, 2015 Author Share Posted May 2, 2015 Nice assistance there Chris Ill do that then. Also, any more on the FCDs? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 2, 2015 Share Posted May 2, 2015 What about the FCD's? I have them in stock as I type. Cheers. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 2, 2015 Author Share Posted May 2, 2015 I posted a pic with the Aristo MAP sensor part number? Ill check the thread, I need one. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 2, 2015 Share Posted May 2, 2015 Ahh the *MAP* sensor, you said FCD above. I have found a couple, I'll check against your photo tomorrow, e-mail me if i forget, go a lot on this weekend, sorry. Cheers. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 2, 2015 Author Share Posted May 2, 2015 I meant FCD, you asked for a picture of the MAP sensor so you could tie the part numbers up Ill email you anyway Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 3, 2015 Share Posted May 3, 2015 I can't find the thread now, but in front of me I have a MAP sensor part number: 89421-12111 079800-3250 I have the gear to measure its output V vac / pressure input and do an FCD to suit. Quote Link to comment Share on other sites More sharing options...
