Ian C Posted February 13, 2002 Share Posted February 13, 2002 And how do I know if it's UK or J spec? -Ian Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted February 13, 2002 Share Posted February 13, 2002 It's in the fuel tank, take out the spare wheel and you will see the coverplate. Not sure how to check the spec though. Quote Link to comment Share on other sites More sharing options...
eyefi Posted February 13, 2002 Share Posted February 13, 2002 anyone used the better than uk spec pump from tdi? Quote Link to comment Share on other sites More sharing options...
Ian C Posted February 16, 2002 Author Share Posted February 16, 2002 Quote: from Martin F on 11:09 am on Feb. 13, 2002[br]It's in the fuel tank, take out the spare wheel and you will see the coverplate. Not sure how to check the spec though. Chees, Martin. I took the wheel out, removed the coverplate, and there it is. I've made a note of the markings on the rim of the pump, and I would like to ask a favour of anyone with a UK spec car - can they have a shufty at their fuel pump and compare the markings with mine? (it's easy to look at, you don't have to touch the pump) TOYOTA PE-HD SAE HDPE 74144-14040 HORIE METAL Cheers -Ian Quote Link to comment Share on other sites More sharing options...
GavinL Posted February 16, 2002 Share Posted February 16, 2002 Hi... I would look but mine has been lobbed away and replaced with an uprated item. You might want to consider this yourself or get someone to flow test it (whatever the spec of pump) just in case it's getting tired. regards..... Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 16, 2002 Share Posted February 16, 2002 Yep get a nice Walbro jobby in there, thats the one to have. Quote Link to comment Share on other sites More sharing options...
Doughie Posted February 17, 2002 Share Posted February 17, 2002 Ian i'll pop out later this morning and check on my UK-spec what the markings are on the fuel pump. cheers Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted February 17, 2002 Share Posted February 17, 2002 hi people i have a j spec 96 supra, think i have read the uk supra has a better fuel pump, could you go just buy a uk pump and fit that with no problems.also where are the fuel filters.just trying to learn about tuning.also whats tha advantages of better fuel pump.is it just has a better pump rate to get more fuel into the engine.is it better if you are upping the boost. i have a de cat pipe and boost goes up when you floor it. i get fuel cut. got a pete betts fuel cut defencer to fit. thanks for any info Quote Link to comment Share on other sites More sharing options...
Alex Posted February 17, 2002 Share Posted February 17, 2002 UK pump is more powerful. using a bigger pump allows more fuel to flow when using bigger injectors and a fuel computer/re-mapped ECU if you upgrade to UK spec injectors then it would be worthwhile uprating the fuel pump to match. The last thing you want is fuel starvation at high boost. Fit the FCD asap you can seriously harm the engine/drivetrain by hitting fuel cut. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted February 17, 2002 Share Posted February 17, 2002 Quote: from Ian C on 12:53 pm on Feb. 16, 2002[br]Quote: from Martin F on 11:09 am on Feb. 13, 2002[br]It's in the fuel tank, take out the spare wheel and you will see the coverplate. Not sure how to check the spec though. Chees, Martin. I took the wheel out, removed the coverplate, and there it is. I've made a note of the markings on the rim of the pump, and I would like to ask a favour of anyone with a UK spec car - can they have a shufty at their fuel pump and compare the markings with mine? (it's easy to look at, you don't have to touch the pump) TOYOTA PE-HD SAE HDPE 74144-14040 HORIE METAL Cheers -Ian OK just done this and the number you have is not of the pump, that is of the assembly or fixture plate. I have the same number on the rim of my plate as well (UK Spec) but that doesn't really mean a lot. You need to remove that assembly (make sure battery is disconnected) and the you will be able to see the pump inside along with the level sensor and other piping. Similar to this :- http://www.vache.org/supra/tmp/dimitri/MVC-004F.JPG This pic show's a modified Supe fuel system with dual Bosch pumps. Sorry i didn't go that far as the light was failing, buit according to the EPCD the part number for a UK pump is 23221-46110 Quote Link to comment Share on other sites More sharing options...
Ian C Posted February 17, 2002 Author Share Posted February 17, 2002 Aha - cheers, Martin. I imagine they are zillions of quid new from Toyota? Is the Walbro one mega expensive as well? -Ian Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 17, 2002 Share Posted February 17, 2002 I can do a replacement Nippon pump for £106.20 + del & Vat. If your interested in the Walbro's I'll find out for you. Quote Link to comment Share on other sites More sharing options...
