krisgowing Posted April 29, 2015 Share Posted April 29, 2015 Alright guys. Looking to get a TT 6-speed but because of my insurance and you've gotta start somewhere I have a stock NA auto. I've read a few threads so far and am I correct in getting the best start and speed would be: Use power braking (read the threads on how to do this) Have the auto box in manual mode , Start in Low till close to the red line. (first gear) Change to 2 and keep till close to red line. (second gear) Then into D for 3rd. First automatic I've owned so just a bit of advice on when I need it to get the best out of it. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted April 29, 2015 Share Posted April 29, 2015 You don't need to change into 3rd gear to reach 60mph And there's no point manually changing gear, if you're flooring the accelerator it will hold the upshift until the last minute. The manual mode on the autobox is more for driving on twisty roads. Quote Link to comment Share on other sites More sharing options...
krisgowing Posted April 29, 2015 Author Share Posted April 29, 2015 (edited) You don't need to change into 3rd gear to reach 60mph And there's no point manually changing gear, if you're flooring the accelerator it will hold the upshift until the last minute. The manual mode on the autobox is more for driving on twisty roads. That was for the fun after 60mph , Just read on the threads that doing it this way would change gear quicker, which would help with the time or not really. Edited April 29, 2015 by krisgowing (see edit history) Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted April 29, 2015 Share Posted April 29, 2015 Just read on the threads that doing it this way would change gear quicker, which would help with the time or not really. Eh? Quote Link to comment Share on other sites More sharing options...
krisgowing Posted April 29, 2015 Author Share Posted April 29, 2015 Eh? I read this: ''MANU makes the transitions between gears faster. The ECTS throttle system cuts back on the throttle during gearchanges, and in MANU mode it cuts back less, therefore making the shifts harsher but losing a bit less acceleration during the gearchange.'' Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted April 29, 2015 Share Posted April 29, 2015 I read this: ''MANU makes the transitions between gears faster. The ECTS throttle system cuts back on the throttle during gearchanges, and in MANU mode it cuts back less, therefore making the shifts harsher but losing a bit less acceleration during the gearchange.'' I know that. You post didn't make sense though or it did. Quote Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted April 29, 2015 Share Posted April 29, 2015 (edited) We dont do speeds over 70mph (national speed limit) inless it is a private road or track This relates to it being comfordable at 125mph Edited April 29, 2015 by Hitbox Junkie (see edit history) Quote Link to comment Share on other sites More sharing options...
Scott Posted April 29, 2015 Share Posted April 29, 2015 You're not really going to be setting the world ablaze so I wouldn't worry too much about the manual mode vs just letting it run. I doubt the TC holds back the power in an N/A anyway. BTW, I'm not NA bashing here, just being objective about how it is. If you can get yourself a hold of a performance meter then you would be able to experiment between manual and full auto. You would need to be really handy with the manual mode and time everything perfectly to beat the full auto though. As previously said, it's more for the twisties and holding a gear while cornering etc. Quote Link to comment Share on other sites More sharing options...
walkerstrider Posted April 29, 2015 Share Posted April 29, 2015 Just use the overdrive, makes no difference using manual in my experience. Quote Link to comment Share on other sites More sharing options...
krisgowing Posted April 29, 2015 Author Share Posted April 29, 2015 You're not really going to be setting the world ablaze so I wouldn't worry too much about the manual mode vs just letting it run. I doubt the TC holds back the power in an N/A anyway. BTW, I'm not NA bashing here, just being objective about how it is. If you can get yourself a hold of a performance meter then you would be able to experiment between manual and full auto. You would need to be really handy with the manual mode and time everything perfectly to beat the full auto though. As previously said, it's more for the twisties and holding a gear while cornering etc. I was just curious that's all, Look forward to my TT sure I will notice a big difference then Yeah, imagine there isn't much in it. Thanks for the help - - - Updated - - - Just use the overdrive, makes no difference using manual in my experience. Yeah I have done and to be honest i don't see much difference with that either. Quote Link to comment Share on other sites More sharing options...
cered Posted April 29, 2015 Share Posted April 29, 2015 I did read up on fast-launches for auto cars, and the consensus is messing about with techniques is a good way to break your transmission (E.g. building up revs in neutral adn then putting it into drive - is this even possible in Supras?) . So be careful and avoid doing too much, just enjoy it for what it is Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted April 29, 2015 Share Posted April 29, 2015 Overdrive off, Left food hard down on the brake, right foot planted on the loud pedal and then release the brake. A stock torque converter car willl stall around 2200rpm before breaking traction. Quote Link to comment Share on other sites More sharing options...
charlton Posted April 29, 2015 Share Posted April 29, 2015 How about for those with TT's already? What is the best/better mods to do to get the time down? Obviously a single but can it be avoided? Or can a smaller single be used without the high expense of other upgrades? Quote Link to comment Share on other sites More sharing options...
