Wideband sensor location
berg
Can anyone confirm the correct place to have a wideband sensor installed on my exhaust
Currently BPU with 1st and 2nd decats
Heard mixed stories regarding how far away from turbos, not sure whether to install in 2nd pipe or 1st
Its an AEM UEGO if that makes any difference
I always fit wide bands near the turbo outlet, they react faster there. Never had issues with Bosch sensors, some installs have had them within less than 4 inches. I have seen manufacturers test engines with wide bands within a couple of inches of each head port, where EGT's will be almost as high as those in the cylinders. After a turbo things are a lot cooler.
