Hello from Finland
Guest Hissmannen
Guest Hissmannen
Hi all,
I need to activate my account very quíckly, because interesting parts are for sale here.. I have -94 E85 converted single turbo under construction. Car should be ready in June and my target ís break 300 km/h in one mail challenge..
See you!
Edited by Hissmannen (see edit history)
Guest Hissmannen
Before rebuild output was 705 hp / 890 nm. Stock engine with Holset HX50 MFS, GSC Power Division stage 2 cams, Link G4 ecu, 4" stainless steel exhaust, EV14 2200cc injectors+E85.
Engine parts for new setup:
Titan billet main caps
Titan crank pulley
Ferrea bronze valve guides
BC valves
BC springs & titanium retainers
BC conrods
Wiseco race 86,5 mm pistons, compression ratio 10:1
Billet cambelt bracket
ARP main & head stud kits
Welded crank sprocket
Water & Oil pump
Altenator
AC delete kit
ACL race bearings
ATI damper
Cylinder head optimized with small modifications
