Help with boot rubbers
Tyson
After the awesome ellis gifted me his spare boot rubbers I thought I'd tackle them today ! My rubbers were different to the ones ellis gave but then I noticed someone had added some extra padding to stop a previous squeak. I cut off the old rubber to be presented with two almost rounded screws :( I have neither the tools of know how to get them out now !! How much would a garage charge to get them out and replace ? I'm a bit stuffed as I am worried the surrounding area is going to get damaged in the process as it's a bit tight.
Carefully flatten the flange around the edge of the rubber mounting plate under the screws. Use a PENCIL blowtorch with some Heath Robinson heat shielding to get the screw heads smoking hot. This will fully kill the Loctite. Use mini Mole Grips to get the remains out whilst they are still hot. DO NOT *NOT* try to drill the screws and use Easi Out type LH thread things on screws this small. They WILL snap off and leave pot hard metal in the remains of the screws. Leave the heads alone. I have seen home garage attempts to get these out result in half in holes in the rear hatch surround and TIG repairs needed...
Able to fit my car in yet Chris ? Could you do this for me ?
A minute with a small blow torch and the Loctite that is used on the bolts melts and they can then be easily removed. Changing the side rubber stops should only be a five minute job. An eternity if you don't heat the threads though.
Indeed, indeed, indeed. Quite why Toyota Loctited the damned things I'll never know.
