Jellybean Posted April 25, 2015 Share Posted April 25, 2015 Any pics for Supra oil cooler installs Quote Link to comment Share on other sites More sharing options...
Jellybean Posted April 26, 2015 Author Share Posted April 26, 2015 Anybody have any pics of an oil cooler installed in the side passenger pod area and the AN fittings on the top, I think it may be a tight squeeze with the TRD bumper ducting Mine is like this at the moment, was thinking of running two brackets from the sump/engine tray area up to it ; any advice or idea's welcome Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted April 26, 2015 Share Posted April 26, 2015 You don't want it mounted in the middle behind the intercooler, we've track tested that position and it doesn't work very well at all. Make sure it's mounted either left or right wherever there's room and try and get it in the airflow as much as possible. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted April 26, 2015 Share Posted April 26, 2015 If you're running an FMIC, surely the stock SMIC position is ideal? It's properly ducted too. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted April 26, 2015 Author Share Posted April 26, 2015 Thanks will try run it right or left Quote Link to comment Share on other sites More sharing options...
Jellybean Posted April 26, 2015 Author Share Posted April 26, 2015 Sorry last Q, can you wirelock those goodridge AN fittings? Quote Link to comment Share on other sites More sharing options...
Kev.O Posted April 26, 2015 Share Posted April 26, 2015 Here's mine, fitted to the passengers side as I'm running a CW SMIC: Quote Link to comment Share on other sites More sharing options...
Kev.O Posted April 26, 2015 Share Posted April 26, 2015 Complete with custom ducting for the stock bumper: Quote Link to comment Share on other sites More sharing options...
Jellybean Posted April 26, 2015 Author Share Posted April 26, 2015 Nicely done sir Quote Link to comment Share on other sites More sharing options...
Kev.O Posted April 26, 2015 Share Posted April 26, 2015 Thank you, hopefully the photos are of some use to you. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted April 26, 2015 Author Share Posted April 26, 2015 Have a good idea what I want to do thanks Just have to see how it all lines up with the TRD ducting Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 27, 2015 Share Posted April 27, 2015 Sorry last Q, can you wirelock those goodridge AN fittings? A correctly tightened AN fitting will not come loose so long as the hose run isn't pulling it round. They do not need wire locking, Loctiting, or using with ANY kind of tape or liquid sealant. - - - Updated - - - Complete with custom ducting for the stock bumper: Text book, nice job. you have even got shrink tube on the braid to stop it cutting through stuff. Quote Link to comment Share on other sites More sharing options...
supra matt Posted April 27, 2015 Share Posted April 27, 2015 Some nice installs guys, they need to be indirect airflow so the air is passing through the cooler and not over it like the ones you see installed at angles its OK to install at an angle as long as its fully ducted so again the air is pushed though it, Quote Link to comment Share on other sites More sharing options...
chazuk Posted April 27, 2015 Share Posted April 27, 2015 You don't want it mounted in the middle behind the intercooler, we've track tested that position and it doesn't work very well at all. Make sure it's mounted either left or right wherever there's room and try and get it in the airflow as much as possible. +1 did this on mine between fmic and rad saw around 127c-130c on hard driving now it's mounted on the passenger side flush with the top secret bumper side pod on hard driving it's around 105c . Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted April 27, 2015 Share Posted April 27, 2015 (edited) Mine. Two things about it not strictly approved of. No ducting on mine. But the washer bottle has since been removed leaving only the louvered lower section of the wing liner behind it. Air has nowhere else to go really. Fittings to the bottom. But the cooler itself is mounted lower than the take-off & return on the oil cooler sandwich plate so it remains full even when there is no oil circulating. I've never see oil temps above 110° even on a hot track day. Edited April 27, 2015 by pedrosixfour (see edit history) Quote Link to comment Share on other sites More sharing options...
Jellybean Posted April 27, 2015 Author Share Posted April 27, 2015 Thanks Guys, Will post up a pic of mine when I have it done Quote Link to comment Share on other sites More sharing options...
Kev.O Posted April 28, 2015 Share Posted April 28, 2015 Thanks for the kind words Chris. Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted April 28, 2015 Share Posted April 28, 2015 Mine below. I need to make up some ally ducting, but you get the idea of the mounts. I'm also going to make a little ally framed mesh guard to stop the stones getting to it. [/img] Quote Link to comment Share on other sites More sharing options...
