markylee Posted April 25, 2015 Share Posted April 25, 2015 I have just bought a celica steering wheel and it comes with an airbag , my current wheel is a momo with no airbag ,can I just put the celica one straight on? I am not concerned about connecting the airbag....thanks Quote Link to comment Share on other sites More sharing options...
RobUK Posted April 25, 2015 Share Posted April 25, 2015 Yeah, should be fine Quote Link to comment Share on other sites More sharing options...
J-Meiser Posted April 25, 2015 Share Posted April 25, 2015 (edited) I swapped my stock 3-spoke, non-airbag steering wheel for a 7th Gen Celica wheel w/airbag and it was a straight swap in terms of fitting it to the column. I never connected up the airbag as I don't have the connections to do so, but as a precaution, I do swap back to my stock wheel at MOT time. I'm not sure how your horn is currently wired up, but I had to wire in a "B" shaped blade connector and slide it on to one of the protrusions on the back of the airbag to complete the circuit for the horn; someone who has an aftermarket setup may be able to assist in this department better than I can. Edited April 25, 2015 by J-Meiser (see edit history) Quote Link to comment Share on other sites More sharing options...
GTR Fever Posted April 27, 2015 Share Posted April 27, 2015 I did the swap as well but my car has dual airbags. Still an easy swap, direct plug-in and bolt-in affair, 15 minute job total. Quote Link to comment Share on other sites More sharing options...
markylee Posted April 28, 2015 Author Share Posted April 28, 2015 Thanks guys, it arrived today, there is a wire that connects to the wheel with a white 6 point connection on it, so hopefully when I take the momo off it will have the same behind, will be doing this next week, the airbag itself has a yellow connection which I am steering well clear of(pun intended) Quote Link to comment Share on other sites More sharing options...
