jza800 Posted April 24, 2015 Share Posted April 24, 2015 (edited) I have this problem with my turbo, what could be my problem, blown turbo or??? sorry for the camera turn around... https://youtu.be/2IYovH9xW6Q Edited April 30, 2015 by jza800 (see edit history) Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted April 24, 2015 Share Posted April 24, 2015 How much boost are you getting? Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 24, 2015 Author Share Posted April 24, 2015 0,8 max Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 24, 2015 Share Posted April 24, 2015 Whats the spec, what turbo? Dump valve? Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 25, 2015 Author Share Posted April 25, 2015 Stock twin turbo stock valve. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted April 25, 2015 Share Posted April 25, 2015 Have you checked for split pipes around the BOV & intercooler? Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 25, 2015 Author Share Posted April 25, 2015 I have change to alu pipes, and new silicone hoses all over the engine, before i fit the engine in the car.. and all hose clamps are well tightened on the intercooler pipes Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 25, 2015 Author Share Posted April 25, 2015 (edited) and the turbo noise starts at -0.1 to the positive boost range.. and at idle, nothing to hear.. you can hear it at rev, but only when you are about 3000 til 4000++rpms. i think it is because i am close to 0 boost range right???? Edited April 25, 2015 by jza800 (see edit history) Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 25, 2015 Author Share Posted April 25, 2015 here is a video off the play, what do you say dead turbo or??? https://youtu.be/ORfCp6xzsXs Quote Link to comment Share on other sites More sharing options...
Ric Posted April 25, 2015 Share Posted April 25, 2015 you shouldnt hear the bov if it's the stock one, which you can, quite loudly so i'd say it's bust, or a broken pipe. Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 25, 2015 Author Share Posted April 25, 2015 where should that be?? all pipes are new?? have you seen the video?? is that shaft play normal??? Quote Link to comment Share on other sites More sharing options...
ATB Posted April 25, 2015 Share Posted April 25, 2015 That does not look like a healthy turbo! Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 25, 2015 Author Share Posted April 25, 2015 I have this spare part laying around, is that good then??? https://www.youtube.com/watch?v=8dS0f2cjYjE&feature=youtu.be https://www.youtube.com/watch?v=kf08PivYqjk&feature=youtu.be Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 25, 2015 Author Share Posted April 25, 2015 That does not look like a healthy turbo! So you would say that i the course off my problem??? Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted April 25, 2015 Share Posted April 25, 2015 I think its going to be hard to say. But go with the basics first: Check all pipes Check all the VSV are working Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 25, 2015 Author Share Posted April 25, 2015 I think i did find the whinning noise to the turbo am i right??? Quote Link to comment Share on other sites More sharing options...
Big Supes Posted April 26, 2015 Share Posted April 26, 2015 Indeed you are. They're caput. Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 26, 2015 Author Share Posted April 26, 2015 Is indeed they are is it posible that is why i am overboosting, because in seq boost like stock.. ttc overboost to 1.2 to 1.4 bar.. Quote Link to comment Share on other sites More sharing options...
Big Supes Posted April 26, 2015 Share Posted April 26, 2015 In your case, I would attribute boost spike to the knackered turbos, definitely. Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 26, 2015 Author Share Posted April 26, 2015 Can you trie to explain how that happen/posible?? It would be a knowledge which is nice to have Quote Link to comment Share on other sites More sharing options...
Big Supes Posted April 26, 2015 Share Posted April 26, 2015 A worn turbo shaft or bearing (probably both in your case) will cause inconsistent spool as well as an inconsistent boost peak. The later is caused, IIRC, due to unstable turbo pressure equalisation on the wastegate. Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 26, 2015 Author Share Posted April 26, 2015 thanks for your answer Quote Link to comment Share on other sites More sharing options...
Big Supes Posted April 26, 2015 Share Posted April 26, 2015 Hope its made sense. Quote Link to comment Share on other sites More sharing options...
paulj1 Posted April 28, 2015 Share Posted April 28, 2015 Single time :d Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 29, 2015 Author Share Posted April 29, 2015 Now i fit new used turbos, same problem as before, But under test drive Somethimg blow off, and now i have no boost at all, it sound like a hose blow off somewhere, have looked all vacum hoses, and all seems to be fine and on place, and it was some rubber sound i heard when it happend, so where to look? Quote Link to comment Share on other sites More sharing options...
