boostman Posted April 24, 2015 Share Posted April 24, 2015 I've just found a split in my front bumper in the pic below. It's attached at the top and bottom but the 15cm in between has split. Has anyone ever repaired a bumper? ....without the use of a wood screw.... [emoji12] Would I be able to use this I found on ebay? http://pages.ebay.com/link/?nav=item.view&id=261863928375&alt=web Thanks Quote Link to comment Share on other sites More sharing options...
JordanC Posted April 24, 2015 Share Posted April 24, 2015 Would filler not do the trick? layer it on until it fills the split then sand back? I'm not an expert by any means, I'm sure someone else will be along to tell me to shut it Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted April 24, 2015 Share Posted April 24, 2015 Mines done the same. Personally if I could be bothered to do anything about it if plastic weld it back together. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted April 24, 2015 Share Posted April 24, 2015 On your photo have you taken a bolt out? It looks like there is a bolt hole above the one that's still in there. Quote Link to comment Share on other sites More sharing options...
boostman Posted April 24, 2015 Author Share Posted April 24, 2015 Mines done the same. Personally if I could be bothered to do anything about it if plastic weld it back together. Oh ok wasn't sure if the bumper would drop down if the split spread!? I think I'll try that glue then as it's like a plastic weld, flexible where as filler would crack. Quote Link to comment Share on other sites More sharing options...
boostman Posted April 24, 2015 Author Share Posted April 24, 2015 On your photo have you taken a bolt out? It looks like there is a bolt hole above the one that's still in there. The bolt was already out, must have dropped out? [emoji50] haha Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted April 24, 2015 Share Posted April 24, 2015 Try and source a stock bolt, surely that pulls it together (I would think) Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted April 24, 2015 Share Posted April 24, 2015 It looks like a seem as well. The combination of no top bolt and the unique flat uk roads has probably made it pull apart. Does the other side look similar like a join in two bits of plastic- albeit with paint over the join? Quote Link to comment Share on other sites More sharing options...
boostman Posted April 25, 2015 Author Share Posted April 25, 2015 It looks like a seem as well. The combination of no top bolt and the unique flat uk roads has probably made it pull apart. Does the other side look similar like a join in two bits of plastic- albeit with paint over the join? I think if I put the bolt back it it will pull it apart more. I see what you mean it is a seam, the other side looks fine (touch wood). Iv ordered that glue, says it's can be sanded and painted and stays flexible so it's worth a shot! Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted June 22, 2015 Share Posted June 22, 2015 Any luck with this mate? Quote Link to comment Share on other sites More sharing options...
MattP Posted June 22, 2015 Share Posted June 22, 2015 Mine was like that on import on the passenger side but Jurgen had it repaired but this year it has come through again.. Quote Link to comment Share on other sites More sharing options...
boostman Posted June 22, 2015 Author Share Posted June 22, 2015 Any luck with this mate? Yeh all fixed now, used some plastic weld glue for gluing bonnet hinges to carbon fibre bonnets! Worked a tread, sanded and painted! Have painted it now, will take a pic in a sec! Quote Link to comment Share on other sites More sharing options...
boostman Posted June 22, 2015 Author Share Posted June 22, 2015 A bit dirty but you get the gist. Hopefully it stays together! [emoji12] Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted June 22, 2015 Share Posted June 22, 2015 Looks good mate. Did you bond it from both sides? Quote Link to comment Share on other sites More sharing options...
boostman Posted June 22, 2015 Author Share Posted June 22, 2015 Yeh I opened the gap and squirted glue behind the plastic! I'll look what the glue was! Quote Link to comment Share on other sites More sharing options...
samgtr Posted June 22, 2015 Share Posted June 22, 2015 I would remove bumper and epoxy bond from inside then like you have done on the outside also. Quote Link to comment Share on other sites More sharing options...
boostman Posted June 23, 2015 Author Share Posted June 23, 2015 Here's the link! http://pages.ebay.com/link/?nav=item.view&id=261863928375&alt=web I put quite alot behind the crack, like half of the syringe haha It probably glued the bumper to the wheel arch! [emoji13] Quote Link to comment Share on other sites More sharing options...
