dude Posted March 27, 2003 Share Posted March 27, 2003 The heading says it all , i have a resistor pack off a uk mk3 turbo , can i use this on my mk4 for a uk injector conversion ??? john:flame Dev Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 27, 2003 Share Posted March 27, 2003 I don't think the MKIII has a resistor pack. Are you sure it's not the ignitor ? Do you have a part number ? Quote Link to comment Share on other sites More sharing options...
Thor Posted March 27, 2003 Share Posted March 27, 2003 Dude you need to find the ohm's of the UK & MK3 then compare. There was an injector database on http://www.autospeed.com a while back. Try there. Good luck & let us know how you get on. Quote Link to comment Share on other sites More sharing options...
Thor Posted March 27, 2003 Share Posted March 27, 2003 dude, if the mk3 engine is a 7MGTE then the injectors are 2.9 ohms. Hasn't got the uk MKiv's. Anyone know? If there are slight differences in the ohms then apparently this is OK. Quote Link to comment Share on other sites More sharing options...
dude Posted March 27, 2003 Author Share Posted March 27, 2003 Thanks guys , Martin i will try and get a part number tommorrow . John:flame Dev Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 11, 2010 Share Posted June 11, 2010 sorry to dig out a necrothread but were these injectors plug and play or is a resistor pack needed with them as have had a 50/50 on answers some say you do some say you dont . thanks Quote Link to comment Share on other sites More sharing options...
kaahari Posted June 12, 2010 Share Posted June 12, 2010 (edited) ^ If your car is import (jdm) , injectors are plug and play BUT you will need resistor pack if you fit UK injectors / other low impedance injectors with stock ecu. Quite easy to fit resistor pack, ~½-1h work There`s good guide: http://www.internetwork.org.uk/mechanical/Injectors/Injectors.htm Edited June 12, 2010 by kaahari (see edit history) Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 12, 2010 Share Posted June 12, 2010 ok thanks , so just to clarify. i can slot a set of mk3 440s in my jdm na mk4 with no resistor pack and they will work? Quote Link to comment Share on other sites More sharing options...
