overflow tank that fits beside battery?
msupra1
My JDM Supra had the small terminal post battery with factory radiator overflow tank put in front of it, ever since I upgraded the terminals to standard size and got a bit larger battery, I have been running a water bottle for my radiator overflow... which I have to empty out every few drives.
I'm trying to figure out an overflow tank that will fit beside the battery.
Any suggestions for any that at compact and smaller? The key thing Is it can't be much taller than 6" if I want to place It beside the battery, otherwise it may hit the hood.
Where's the filler neck for your washer jets gone?
I also fitted a civic one, which fits neatly, though I had to cut a small section of the lip of the battery tray.
I'd taken it off in that previous photo so i could paint it black :)
Thanks for the photos! It looks like I'll go with the Civic overflow. I did a search and found the part numbers.
I don't mind cutting the battery tray to get it fit.
I noticed yours is black. Was that painted? seems like they come in the yellow'ish plastic material.
edit: I noticed your windshield washer fluid tank.. that's black. I guess it was just painted.
Yes mate i painted the expansion tank and the washer fluid filler black
