Offset question
TRD-Rob
Yeah should be very close without needing arch work. Someone may have those actually offsets on their supe.
Mine are 8.5, 9.5 with offset 31 on both. I could spacer the fronts, but the tears are close enough.
You seem pretty clued up at this :D
My wheels are going to be approx 8x18 ET25 front with a 235/40 tyre, and 9x18 ET25 with a 255 tyre (for now). I'm guessing it will look a little more tame than mikes, but still agressive?
I should be... Hopefully ha.
I spent a couple of month reading people's wheel sizes and offsets, using will they fit dot com, looking at photos, before buying mine.
Yours will have near the exact same look as mine in regard to where the outer edge of the rim sits... You'll just have far better looking wheels ha.
