Electronic windows
Guest drakie
Guest drakie
Gents I know this has been covered a few times both drivers and passenger windows not working how much is this likely to cost to get fixed.
I am pretty good with most things if it's wires I will be able to sort out but if it's switches or something what sort of cost are these parts and how easy to get hold of.
Cheers steve
Cheers steve
i take it fuses have been checked. has it got or had a remote alarm with a window closer module.
is it just drivers side switch or does the pass side work the window?
  • 2 weeks later...
Guest drakie
Passenger window goes up and down from drivers door and goes down from passengers door but not back up drivers window does not work at all??
i will have a check on wiring details regarding pass side problem. have you removed the drivers side trim and checked motor ẃith a test light and the cables/ mechanism is ok, not sure if it's s common problem with the cables jamming, as the car is new to you previous owner could have wedged window up because of broken cable? i would start by taking door card off.
regards chris
in your first post you said both sides were not working? what has now changed to how it is now?
Edited by chrispot
added something else (see edit history)
Guest drakie
I've got the door card off had a look at the switch but not used a test light yet mate.the little led in the switch lights up for the drivers switch? And the passenger switch works ok on drivers side do they all have a separate live?
Cheer steve
found a manual for you to look at, as you will see there is only one fuse for the electric windows. I don't know what you are like at reading wiring diagrams but if you study the diagram you will see that the passenger side window works through the drivers side passenger switch.
Regarding the pass side window using the pass side switch it close i would say the pass side switch is faulty, as it works from drivers side proving the negative connections, and only getting live to power window down from pass side and not up.
regarding drivers side put a test light on one side of the motor and move switch in both directions and it should light up then do the same on the other wire. if both ok check that both wires on the motor are at ground with no switch operated, if both at ground then i would say motor is faulty, but to confirm unplug motor and put power into wires and see if motor moves, don't forget to reverse wires as you might be trying to move the window up?
http://www.internetwork.org.uk/manual/system/windows/windows.htm
regards chris.
Guest drakie
First post was for a different car mate I did not buy coz it was to much work.
I have found the fault now the cable for the window mec has broken can this be replaced or is it a new unit? And does anyone know where I can buy one from?? Also need a passenger window switch??
Thanks for the help
it's best to keep to one car per thread when asking for help to fix a problem. as you may be given wrong advice.
I would get in touch with keron (extreme performance ) a trader on here regarding motor and switch.
your welcome, glad it's sorted.
regards chris
If you have the door card off its easy to check the motor, you can just wire it up to 12v, changing the polarity changes window direction from memory, I had to do this when stripping some doors down that were off the car and partially stripped.
  • 2 months later...
