Twin turbo Posted April 21, 2015 Share Posted April 21, 2015 (edited) Looking at the transmission dipstick on my 93 jdm supra it says dexron T- II but from what i read in the forum People recommend toyota Atf IV! Is it the same or will it destroy the gaskets in my transmission.my dealer has dextron T IV in stock but they found another type from the database Edited April 22, 2015 by listy Swearing (see edit history) Link to comment Share on other sites More sharing options...
David P Posted April 22, 2015 Share Posted April 22, 2015 Dexron III will work fine, Toyota Type IV is better. Link to comment Share on other sites More sharing options...
Shane Posted April 22, 2015 Share Posted April 22, 2015 ATF-U as sold by GSF is supposedly a replacement to Toyota Type IV according to the application list on the back of the bottle. Link to comment Share on other sites More sharing options...
Scooter Posted April 22, 2015 Share Posted April 22, 2015 as is Mobil ATF 3309... Link to comment Share on other sites More sharing options...
Twin turbo Posted April 22, 2015 Author Share Posted April 22, 2015 OK thankyou will Get some T-IV then. And my mistake it did not say dextron only T-II Link to comment Share on other sites More sharing options...
Swampy442 Posted April 23, 2015 Share Posted April 23, 2015 Dex III is fine, theres no need to run type IV, but bear in mind you can't mix the fluids as they are not compatible, so you'll need a good few litres to flush all the old fluid out first. Link to comment Share on other sites More sharing options...
