Bayden_uk Posted April 21, 2015 Share Posted April 21, 2015 Ok guys i've done a search on here and on Google but cant seem to find the answers or any solution to my problem. Ok. at first when I start driving its fine there's no noise. but after a short while i start to get a knocking (its more of a thud) from the rear end. thuds are a bit heavy too and its worse when im breaking. noise usually starts after i've been driving fro about 20 minutes. also I have a knocking noise on the front end when I go over any small bumps. The knocking on the front end i can feel in the peddles and in the steering wheel its that bad. thanks in advance guys. Ben Link to comment Share on other sites More sharing options...
RobUK Posted April 21, 2015 Share Posted April 21, 2015 Have you checked the subframe bolts? Common thing on the front sub frame.... Worth checking Link to comment Share on other sites More sharing options...
Bayden_uk Posted April 21, 2015 Author Share Posted April 21, 2015 Have you checked the subframe bolts? Common thing on the front sub frame.... Worth checking thanks fro the reply rob ill give that a look see as soon as a get a day off mate. cheers any clue what's up with the back end mate? Link to comment Share on other sites More sharing options...
RobUK Posted April 21, 2015 Share Posted April 21, 2015 Same thing.... There's a rear sub frame:) worth checking as its a simple fix... Link to comment Share on other sites More sharing options...
Bayden_uk Posted April 21, 2015 Author Share Posted April 21, 2015 Same thing.... There's a rear sub frame:) worth checking as its a simple fix... great stuff mate. i have a starting point anyone ells have any other ideas? Link to comment Share on other sites More sharing options...
np89 Posted April 22, 2015 Share Posted April 22, 2015 Suspension struts leaking? Link to comment Share on other sites More sharing options...
Nic Posted April 22, 2015 Share Posted April 22, 2015 It could be one of any number of things, you really need to get the car on a ramp and get it thoroughly checked over underneath by someone who knows what they are doing. Link to comment Share on other sites More sharing options...
Chris Bailey Posted April 22, 2015 Share Posted April 22, 2015 (edited) As above. Try get the car up on a ramp, give every bolt a tap with a hammer and listen out for anything unusual. Also worth checking things like heatsheilds etc. Maybe also check the engine and gearbox mounts for wear. As well as suspension components . Edited April 22, 2015 by Chris Bailey (see edit history) Link to comment Share on other sites More sharing options...
Bayden_uk Posted April 22, 2015 Author Share Posted April 22, 2015 Thanks for the replies guys. Soon as I get a day off I'll get that checked out. I now have a check list Much appreciated Link to comment Share on other sites More sharing options...
Bayden_uk Posted May 18, 2015 Author Share Posted May 18, 2015 ok so i finaly got a day off today. managed to get the car up on the ramps in my mates garage. we checked everything underneath. sub frame, engine mounts, gearbox mounts. suspension, the lot. they were as tight as they can get. took it for a drive and nothings changed. still knocks on the bumps. as for the knocking on speeding up and slowing down, that seems to come and go as it pleases. I was driving down the road the other day and it was knocking. there was a nasty hole coming up in the road so i thought 'f$ck it! im gunna hit it and see if it sorts the problem' funny enough it did for about 10-20 minutes. anyone ells have any more ideas? hoping im slowly closing in on the problem Link to comment Share on other sites More sharing options...
shaz2010 Posted May 18, 2015 Share Posted May 18, 2015 Could be your brake pads moving around as the shim kit isn't doing its job. Sounds similar to mine and that was it. Link to comment Share on other sites More sharing options...
Bayden_uk Posted May 18, 2015 Author Share Posted May 18, 2015 Could be your brake pads moving around as the shim kit isn't doing its job. Sounds similar to mine and that was it. replace the discs an pads all round then eh? see who that goes. cheers Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted May 19, 2015 Share Posted May 19, 2015 Stupid thought but make sure all your wheel studs are still in place. I had a similar problem during acceleration and when I was done prodding about at sub frame bolts I decided to jack the back up and take the wheels off only to discover 2 studs where gone and one more had broken enough to lose the nut on one wheel and the opposite wheel had lost a couple aswell. It seemed to be a fairly common thing on here at one point people losing wheel studs. Link to comment Share on other sites More sharing options...
Nic Posted May 19, 2015 Share Posted May 19, 2015 What suspension is fitted? knocking could be coming from worn suspension top mounts. Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 19, 2015 Share Posted May 19, 2015 If it's the pads rattling / knocking just lightly resting your left foot on the brake to load the pads up would stop the noise. If you have aftermrket coil overs I would suspect them, many are truly dire inside, if they are gas charged and they have lost their pressure the floating piston will knock. The pistons come loose or fail, and will knock. Most spherical bearings in them are a totally inadequate spec and start knocking after a while as they wear. Also check the anti roll bar bushes and link rods. Link to comment Share on other sites More sharing options...
krisgowing Posted May 19, 2015 Share Posted May 19, 2015 Had this problem with mine. Turns out my rear shocks were in a mess! Mine leaked a little oil out by the rears have you got any of that? Link to comment Share on other sites More sharing options...
krisgowing Posted May 19, 2015 Share Posted May 19, 2015 (edited) Stupid thought but make sure all your wheel studs are still in place. I had a similar problem during acceleration and when I was done prodding about at sub frame bolts I decided to jack the back up and take the wheels off only to discover 2 studs where gone and one more had broken enough to lose the nut on one wheel and the opposite wheel had lost a couple aswell. It seemed to be a fairly common thing on here at one point people losing wheel studs. I checked my wheel nuts the other day and saw someone fitted a normal nut to where my stud use to be Edited May 19, 2015 by krisgowing (see edit history) Link to comment Share on other sites More sharing options...
Bayden_uk Posted July 10, 2015 Author Share Posted July 10, 2015 Figured it out in the end. My break disk had a huge crack in it! Link to comment Share on other sites More sharing options...
Nic Posted July 10, 2015 Share Posted July 10, 2015 You've braked your break disc. Link to comment Share on other sites More sharing options...
Bayden_uk Posted July 11, 2015 Author Share Posted July 11, 2015 You've braked your break disc. Exactly [emoji23][emoji85] Link to comment Share on other sites More sharing options...
Dnk Posted July 11, 2015 Share Posted July 11, 2015 You've braked your break disc. Link to comment Share on other sites More sharing options...
Paul372 Posted July 12, 2015 Share Posted July 12, 2015 I had this on mine I changed a lot of parts before I found out what is was, I changed the engine mounts, arb bushes, drop links but it turned out to be where I had the supe fully geo setup that they hadn't done the bolts up tight enough, only got about half a turn on each bolt but that was enough to stop the knocking Link to comment Share on other sites More sharing options...
