Which alloy rad for auto
berg
Yeah auto rads have a section in them that is a gearbox fluid cooler, but you can fit a manual rad and a seperate cooler.
I had to replace one years ago and just got a 52mm aluminium auto one on eay from Hong Kong I think it was. No issues at all and looked good.
I've just had a Whifbitz alloy rad fitted and a separate SRD gearbox cooler kit as well.
It's horses for courses, you have plenty of options available to you whether it be an eBay rad or an OEM one etc, but as long as you've got the cooling for your box retro fitted.
I've seen kits on eBay pretty cheap that could be used for the gearbox cooler, I'm sure someone who done similar will be along soon...
Ah i see, i was trying to ind a hose or something on the bottom that might have been gearbox related but couldnt see one, ill probs go for a seperate cooler for the box i reckon
Mine has a new oem rad which was fitted just before i bought the car but the tabs that the rad cap slot into are chewed so the cap is worrying loose
Car makes hissing/bubbling sounds when i switch it off, if i push the top of the cap down the noise stops
Spose i could but its the tabs on the rad that are chewed up
Almost looks like the cap hasnt been pushed down enough before turning, several times of that happening has damaged them
Ill try on though as that could save a heap of cash
With how my engine is currently looking i know if i buy an alloy rad, then ill buy srd fans, then polished pulleys, etc lol
