2JZ GE Air Filter/Induction Kit
Guest loughman
Guest loughman
Hidi all
My 2JZ GE 1995 Supra currently requires in new air filter element for the induction kit.
The current foam element measures 210mm at base diametre, is 100mm in height and the top diametre is 150mm. The element is surrounded by mesh both internally and externally. The housing is stamped 'Trust Co Ltd' and the hose is stamped 'airnix.' I am having difficultly locating this filter element. I would greatly appreciate it if anyone could point me in the right direction.
If i cannot obtain this element could anyone recommend a good replacement air filter, e.g 'Ramair', 'K and N' etc
Thanks guys
Guest loughman
Apexi is another good brand to look at buddy :)
Thank You. Will bear that in mind
- - - Updated - - -
Spot on. Thanks very much
