Tyson Posted April 18, 2015 Share Posted April 18, 2015 Where's the best place to get these and is it worth replacing all four or just the lowers ? Link to comment Share on other sites More sharing options...
j_jza80 Posted April 18, 2015 Share Posted April 18, 2015 Where's the best place to get these and is it worth replacing all four or just the lowers ? I've just done this today, and although it appears to be the bottom ones that cause the issues, it is worth doing them all. Whifbitz or Steve Manley are probably your best bet, I used my local Toyota dealer Link to comment Share on other sites More sharing options...
Tyson Posted April 18, 2015 Author Share Posted April 18, 2015 I've just done this today, and although it appears to be the bottom ones that cause the issues, it is worth doing them all. Whifbitz or Steve Manley are probably your best bet, I used my local Toyota dealer How much did they cost ? Link to comment Share on other sites More sharing options...
j_jza80 Posted April 18, 2015 Share Posted April 18, 2015 I can't remember, getting on for £40 I think. Link to comment Share on other sites More sharing options...
ATB Posted April 18, 2015 Share Posted April 18, 2015 Just changed mine and It made a world of difference! Got mine from Whifbitz. Link to comment Share on other sites More sharing options...
Rwbjj Posted April 18, 2015 Share Posted April 18, 2015 Just changed mine and It made a world of difference! Got mine from Whifbitz. Fitted mine from Whifbitz a few months ago. Similarly to ATB, made a huge difference. I bought both but it was the bottom ones that had gone. I had to use a dremmel to get one of the screws out. ~ Ben Link to comment Share on other sites More sharing options...
Westcoaster Posted April 18, 2015 Share Posted April 18, 2015 Next on my list of jobs to do on my Supra, anyone have the part nos? Link to comment Share on other sites More sharing options...
j_jza80 Posted April 18, 2015 Share Posted April 18, 2015 Here you go 2x 67293 CUSHION, BACK DOOR LOWER STOPPER 4x 90159-50116 BOLT. 2X 67281B STOPPER, BACK DOOR, LOWER 2X 90109-08055 BOLT That is a full set with fixings. The top two items on that list are the lower rubber blocks & fixings that attach to the body. The other two are the top ones that attach to the boot lid. Link to comment Share on other sites More sharing options...
Westcoaster Posted April 19, 2015 Share Posted April 19, 2015 Cheers! Link to comment Share on other sites More sharing options...
Tyson Posted April 19, 2015 Author Share Posted April 19, 2015 Will get these ordered definitely need this done before dragonball !!! Link to comment Share on other sites More sharing options...
ellis Posted April 19, 2015 Share Posted April 19, 2015 I think I have a set in the garage mate - if I do, you're welcome to them. PM me your address and I'll send them off to you. Link to comment Share on other sites More sharing options...
j_jza80 Posted April 19, 2015 Share Posted April 19, 2015 Just a heads up, there's a guide somewhere that instructs you to cut the old blocks off, then heat the bolts up with a soldering iron as it eases removing them. I didn't follow this guide, and had to drill one of my old bolts. Link to comment Share on other sites More sharing options...
MattP Posted April 19, 2015 Share Posted April 19, 2015 My bolts wouldnt move so I used my mams cheap Hair Dryer on high heat and they came straight out no fuss.. Matts Top Tips Link to comment Share on other sites More sharing options...
Tyson Posted April 19, 2015 Author Share Posted April 19, 2015 I think I have a set in the garage mate - if I do, you're welcome to them. PM me your address and I'll send them off to you. Do you have the bolts too ? If so that would amazing !!! Link to comment Share on other sites More sharing options...
MattP Posted April 19, 2015 Share Posted April 19, 2015 Do you have the bolts too ? If so that would amazing !!! They are just M6 bolts stick some Stainless ones in and forget about them rusting in Link to comment Share on other sites More sharing options...
ellis Posted April 19, 2015 Share Posted April 19, 2015 I believe I do! Link to comment Share on other sites More sharing options...
Tyson Posted April 19, 2015 Author Share Posted April 19, 2015 I believe I do! Pm en route Link to comment Share on other sites More sharing options...
ellis Posted April 19, 2015 Share Posted April 19, 2015 Two brand new boots rubbers and 4 shiny bolts and washers found - will be heading your way asap - bye bye squeaky boot! Link to comment Share on other sites More sharing options...
Tyson Posted April 19, 2015 Author Share Posted April 19, 2015 Two brand new boots rubbers and 4 shiny bolts and washers found - will be heading your way asap - bye bye squeaky boot! My hero Link to comment Share on other sites More sharing options...
JayJay1374 Posted April 19, 2015 Share Posted April 19, 2015 My bolts came out no issue when I painted the shut line. But today I noticed the start of the infamous banging. Link to comment Share on other sites More sharing options...
Pixelfill Posted April 20, 2015 Share Posted April 20, 2015 My bolts came out no issue when I painted the shut line. But today I noticed the start of the infamous banging. Ah that's sold it for me then, I was expecting a squeaking noise from previous posts I'd read. My rear has been knocking / banging for a while and wondered whether the boot rubbers would clear it up. sounds like it will. Link to comment Share on other sites More sharing options...
JayJay1374 Posted April 20, 2015 Share Posted April 20, 2015 They squeak at first. But then bang when they get worse. £33 on whifbitz at the minute. Link to comment Share on other sites More sharing options...
