abs light stays on.. **problem solved**
jza800
ok. but i cant get the abs light to flash when i bridge e1 to tc, it is only the slip off con that flashes like there is no error??? the abs control/block have been removede from the engine bay, because off paint, everthing have been removed from the enginebay because off paint.. i have bleeded the brake system with no problem.. so what can it be???
