Guest steburke Posted April 17, 2015 Share Posted April 17, 2015 Hi all Getting ready to change all the bushings in my supra with mostly polyurethane ones and solid ones where unable to find polyurethane. just need some help in confirming i have all that i need and not missing any here the list R2 Racing Control Arm Bushing Kit Front R2 Racing Control Arm Bushing Kit rear SPF3031K JZA80 Rear Trailing Arm R2 Racing Steering Rack TRD front and rear sway bars SPF2553K Rear Cross-member Supplement Washers (Front Mount, 4 Bushings) SPF2520K Rear Cross-member Supplement Washers (Rear mount, to be fitted into original bushing, 4 Bushings, 4 Washers) SPF3269K Rear Sub Frame Rear Bushing (Replaces original bushing, 2 Bushings, 2 Inner Tubes, 2 Outer Shells, 4 Washers) SPF2967K Rear Differential Pinion Mount Bushing (Upper is replacement bushing, lower is insert to original rubber bushing, 4 Bushings, 2 Washers) Power house racing rear Differential Bushings (aluminium) Is there any missing from this list? Also with the ones that use original bushings would it be worth getting new oem ones as well? and does anyone have the part numbers? Thanks in advance Stephen Quote Link to comment Share on other sites More sharing options...
