Fitting aerocatch's???
JamieP
  • Replies 58
Posted Images
I don't like where they have been fitted, I'm going to do mine like jamesys. I've ordered a couple different size hole saws. Should be pretty easy to do.
I use a jigsaw with aluminium blade it easy enough takes an hour tops, then I fill the underside with p38 - 40 to make it look all factory underneath,
Are your 80miles from me bit to far mate your be fine doing it you have plenty of common sense, just put plenty of masking tap on the top and then you can mark it all out,
Use square on the front edge of the bonnet to get the line then just put the template on the masking tape and draw round it,
Then jigsaw it out :-)
