Fitting aerocatch's???
JamieP
  • Replies 58
Posted Images
I have noticed lift on mine it worried me at first but I just ignore it now. I think aero catches suit certain cars but on a stock bonnet /stock looking car it just does not look right . For peace of mind I replaced the whole latch/cable assembly with new Toyota parts. I did think about some sort of better safety catch maybe a clip chain, I know the bonnet would still bend being alloy but cheaper than it hitting the windscreen and roof.
Check this bonnet lift at 0.35 on
Edited by chazuk (see edit history)
I followed hodges guide too.
It's really easy, just make sure you have a dremmel with decent cutting discs handy. Took me about an hour to cut the holes.
All I will say is check check and check another five times before you cut. I scrapped a bonnet because I got it a bit wrong and nothing lined up :taped:
did my mates on his RX7 with a dremel and a carbide bit he borrowed from work
never again, just take them to a body shop, they were a right pain in the arse.
but, tips:
Mask up the area + a good few inches incase of slippage
template them up and mark in place with a sharpie (template included)
drill holes around the edge of the cut and join up using a dremel and strong bit
file smooth
be aware that you'll often be cutting through 2-3 skins of bonnet so it will take a while, took me hours and hours but then again, I'm not a bodyshop guy
