robby a Posted April 11, 2015 Share Posted April 11, 2015 All parts listed are from a 96 jspec engine that's covered 60.000 miles All prices are posted. All good condition Igniter £20 Coil £15 Distributor, Cap&Leads £55 More parts to come. Anything you need just ask. Thanks Pair of engine mounts with brackets. £65 posted ABS master cylinder £25 posted http://images.tapatalk-cdn.com/15/05/11/693177940cb3d2641c2dca7572579ced.jpg Manual ECU £45 posted http://images.tapatalk-cdn.com/15/05/11/9c69e050995723146119c9c43694caa5.jpg Exhaust heat shield £20 posted http://images.tapatalk-cdn.com/15/05/11/10f9a3da3227ac7dad635e163ac62b61.jpg 3water pipes £25 posted http://images.tapatalk-cdn.com/15/05/11/f0f8ad7b3e32cb8bb0556e76848b79b4.jpg dcbf4de61f773bc9afcda5ae3978ea2b.jpg[/img] Link to comment Share on other sites More sharing options...
Justin Bieber Posted April 11, 2015 Share Posted April 11, 2015 Engine loom? Manual if possible? Link to comment Share on other sites More sharing options...
robby a Posted April 11, 2015 Author Share Posted April 11, 2015 I've got a loom but I've cut one of the fuse box connectors off for my tt loom Link to comment Share on other sites More sharing options...
Justin Bieber Posted April 11, 2015 Share Posted April 11, 2015 How much would you be after for it? Is it a manual loom? Link to comment Share on other sites More sharing options...
robby a Posted April 11, 2015 Author Share Posted April 11, 2015 Yes it's manual. Here's a couple of pics Pm me an offer bud Link to comment Share on other sites More sharing options...
james_cbr Posted April 11, 2015 Share Posted April 11, 2015 the oil cooler mounting bolt with the oil pressure sender in it ? Link to comment Share on other sites More sharing options...
robby a Posted April 12, 2015 Author Share Posted April 12, 2015 the oil cooler mounting bolt with the oil pressure sender in it ? Is this what you need Link to comment Share on other sites More sharing options...
james_cbr Posted April 12, 2015 Share Posted April 12, 2015 yep as long as its threaded in the end Link to comment Share on other sites More sharing options...
alaing Posted April 13, 2015 Share Posted April 13, 2015 Do you have the timing belt covers please ? Link to comment Share on other sites More sharing options...
robby a Posted April 13, 2015 Author Share Posted April 13, 2015 yep as long as its threaded in the end Do you mean inside the end of the bolt ? Link to comment Share on other sites More sharing options...
robby a Posted April 13, 2015 Author Share Posted April 13, 2015 Do you have the timing belt covers please ? Sorry no. They've gone Link to comment Share on other sites More sharing options...
Fizzy T Posted April 13, 2015 Share Posted April 13, 2015 He will, a hole in the end with an internal thread so a sender can be fitted. Link to comment Share on other sites More sharing options...
robby a Posted April 13, 2015 Author Share Posted April 13, 2015 No hole in the end of this one Link to comment Share on other sites More sharing options...
james_cbr Posted April 13, 2015 Share Posted April 13, 2015 ah damn Link to comment Share on other sites More sharing options...
robby a Posted April 20, 2015 Author Share Posted April 20, 2015 Bump Link to comment Share on other sites More sharing options...
David P Posted April 20, 2015 Share Posted April 20, 2015 yep as long as its threaded in the end Drill and tap one. Link to comment Share on other sites More sharing options...
thatwhitecar Posted April 21, 2015 Share Posted April 21, 2015 Have you got any headlights for sale mate or only under the bonnet stuff? Link to comment Share on other sites More sharing options...
calsupra Posted April 21, 2015 Share Posted April 21, 2015 do you have the throttle position sensor on the throttle body? if so will it work on a pre facelift na? Link to comment Share on other sites More sharing options...
robby a Posted April 22, 2015 Author Share Posted April 22, 2015 Have you got any headlights for sale mate or only under the bonnet stuff? Just under bonnet stuff sorry! Link to comment Share on other sites More sharing options...
robby a Posted April 22, 2015 Author Share Posted April 22, 2015 do you have the throttle position sensor on the throttle body? if so will it work on a pre facelift na? Yeh I've got one of those. Don't know if they are the same tho. £20 posted Link to comment Share on other sites More sharing options...
robby a Posted April 25, 2015 Author Share Posted April 25, 2015 Head, crank and sump are sold for those of you who have pm,d me Link to comment Share on other sites More sharing options...
robby a Posted May 12, 2015 Author Share Posted May 12, 2015 More parts added. Link to comment Share on other sites More sharing options...
brom86 Posted May 12, 2015 Share Posted May 12, 2015 U got an alternator? Link to comment Share on other sites More sharing options...
robby a Posted May 12, 2015 Author Share Posted May 12, 2015 U got an alternator? No sorry bud Link to comment Share on other sites More sharing options...
robby a Posted May 12, 2015 Author Share Posted May 12, 2015 do you have the throttle position sensor on the throttle body? if so will it work on a pre facelift na? Part no: 89452-33010 Link to comment Share on other sites More sharing options...
