Odometer and Trip Meters no longer working
J-Meiser
Hello!
The orange engine light and red warning light kept coming on whenever I went above 50 MPH, both lights would eventually go out and once they had, my cruise control would start working. My odometer and trip counters have always worked fine and so have both the rev counter and speedometer.
Today, after doing some research on the forum, I took apart the dash and joined the red/blue wire into the pink wire and after resetting the ECU, I went for a test drive - no more warning lights and cruise control works from the outset :yahoo:, however, neither my odometer or trip meters count up any more :(; the rev counter and speedometer both work fine.
Has anyone else experienced this issue after doing the wire mod behind the dash and if so, can you point me in the right direction to resolve this new problem? If not, I'll just put the wires back to stock and live with the warning lights :(.
Thanks!
