What you think and what's needed
Guest haydon
Guest haydon
*1994 UK spec Supra Auto, 3.0L Twin Turbo gte
Stock Uk Turbos
The manifolds were skimmed and new gaskets,lines and engine seals were fitted throughout.
Rebuilt the block-rehoned, decked, cleaned and balanced with: *New OEM pistons,
New OEM Rings
New OEM Rods
ACL Race Bearings
ARP rods Bolts
A new Crankshaft was fitted and lightened and balanced to custom SRD Spec.
Other parts include:
SRD Stage 1 Race Head
SRD 264 Cams
SRD transmission oil cooler
SRD alloy radiator
SRD expansion tank
SRD Electric fans (removed viscous fan)
SRD Cooling Plate
ARP head bolts
Titan Cam Pullys
New Crank Pully
SRD lightened polished pullys
New starter motor
EGR removed.
Upgraded Braided fuel line(removes pulsation dampner)
New Toyota oil filter
New UK Spec fuel pump
Refreshed 550 injectors with new insulators
Superspark coil packs
New toyota coolant hoses, Breather Pipes etc.
Blitz FMIC
3 inch straight through from turbos. SRD Downpipe, TB Flexipipe and Whifbitz Stainless system
AEM AFR GAUGE
Apexi AVC-R
Apexi SAFC-II
Thinking of going single? As worrying about the stock turbos failing soon?
Do I need anything else ? How much power could I gain?
How much brake could I put out without worrying about blowing the motor. As far as injectors go how big 700 ish
Your engine would be good for 750+bhp. I'd go for 1100cc ASNU injector kit.
You will also need a bigger fuel pump.
*Edit, also looking at your spec sheet, id advice new coil packs because them Superspark ones often start missfiring when you up the boost. Just something to think about :).
Guest haydon
Cherz Chris. First turbo car iv owned still new to this side of things.
What's a guess price on running like 650 bph? Work likely to be done at srd ;) as engine was built there and your local to me
I'd be getting in contact with a Lee at SRD, he will sort you out :) you will be in safe hands!
Have a look at Lee's new SRD single kit. A journal 6266 will be fine and will make your power goal no problem.
Lee will also be able to supply and fit suitable ansu injectors and a syvecs ecu with the necessary sensors.
Being a UK spec you'll already have 4pot/2pot brakes so not much else is needed.
However it may be worth budgeting for an SRD built auto box with paddle shift or a 6 speed conversion as your stock box won't last very long.
