advice on servicing 2jzge
Guest jay0913
Guest jay0913
hi guys i recently purchased an na supra and by the service history it looks like it hasn't been serviced in 6 years!! so my question is whats the best parts to change on my engine to revive it again? she seems really down on power, of course i will need spark plugs,ht leads,oil filter,oil, and I've also replaced the battery. I was also thinking of replacing the pulleys with lightweight ones and the timing belt is there anything else i should change? thanks
Guest jay0913
i know i know haha its an na but its only temporary, looking to do a tt swap next year, she's a manual 5 speed, but in the mean time i need to get her through show season so need to get her running as sweet as possible
Guest jay0913
awesome :) thanks been searching the forum on how to remove the throttle body to get to the plugs because i think they're are hidden bolts somewhere is there a guide?
Fuel filter, air filter, if it's an auto maybe the transmission fluid and check the brake and fuel lines for wear. Also it's an NA so it will be down on power ;)
What's your problem Mr.Frog. 😀
Some people thought we had a turbo under the bonnet 😀 those people have turbo's 😀
Going to do mine soon aswell, heres what i have so far
Air filter
Oil filter
New engine oil (it's black as the night)
Clutch
Spark plugs
Brake discs rears (these are worn, check what brake discs are worn with you)
Brake pads rear (obv when you change the discs :p)
All the windshieldwipers
Timing belt including tensioner
Serpentine belt (preferably with tensioner)
water pump (including gasket)
new fuel filter
new oil drain plug
As for the fluids
New coolant
New engine oil (as mentioned before)
New break fluid (with flush)
New gearbox oil
New differential oil
New windshield washer fluid
Fill up the airco
I'm sure i still forgot some stuff, but i'm still looking for everything aswell.
(didn't forget the power steering, already flushed that like 5 times trying to repair a leak lol)
Mines an NA 1993 JDM
