2JZMKIV Posted April 7, 2015 Share Posted April 7, 2015 Hello, i bought Digital Wideband UEGO Air / Fuel Ratio Gauge UEGO controller 52mm, Bosch 4.9 LSU sensor i have connected the gauge but not the lsu sensor question is can i get rid of the stock o2 sensor plug the lsu sensor where stock o2 sensor was and connect it to the gauge and from there to the ecu(infinity 8) or does the stock sensor has to stay and lsu sensor needs welding and connecting seperately ? car is 96 toyota supra tt bpu 6 speed. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 7, 2015 Share Posted April 7, 2015 As the ecu doesn't need a narrow band sensor if fed the signals from the wide band's controller, you can remove the stock O2 sensor from the turbo elbow and fit the wideband and connect it to the controller with the supplied loom. To fit the wideband you will need a two bolt to 18mm threaded adaptor. I may have a couple in stock, with the correct gaskets. The stock O sensor is not a screw in type like the 4.9 Bosch sensor. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 8, 2015 Share Posted April 8, 2015 It will depend on whether its been mapped using the std lambda feedback or not, if it has then you will either need to feed the wide-bands simulated narrow band to the ECU, or have it remapped using the wide-band sensor feedback, if its been mapped with lambda feedback turned off you will have no problems. Quote Link to comment Share on other sites More sharing options...
2JZMKIV Posted April 9, 2015 Author Share Posted April 9, 2015 I have the aem uego gauge type controller but how am i going to connect it to the infinity does anyone know? Quote Link to comment Share on other sites More sharing options...
2JZMKIV Posted April 9, 2015 Author Share Posted April 9, 2015 I took the stock o2 sensor out fit the bosch 4.9 lsu sensor exhaust has been modified but how am i going to enable lambda feedback how to connect the white cable from the gauge to the ecu To enable the feedback? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 9, 2015 Share Posted April 9, 2015 I would ask the sellers of the ECU, is there not a manual for it? Or ask your mapper. I doubt many people in the UK are familiar with it. I have never even seen one, sorry. Quote Link to comment Share on other sites More sharing options...
