Clausz Posted July 22, 2015 Share Posted July 22, 2015 Somewhere around 1400 pounds. I bought a kit for my drifter. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted July 22, 2015 Share Posted July 22, 2015 Believe it's about £2k Marc Plus propshaft, pedals, clutch slave. Tunnel alterations? When you take all these things into account, plus labor, and include the difference in value between this and a V160/V161 equipped car, I can't see how it makes financial sense. Quote Link to comment Share on other sites More sharing options...
safcdixon Posted July 22, 2015 Share Posted July 22, 2015 1.4k isnt bad like 2k is a touch steep if it is as high as that, the gearbox is only a few hundred quid the prop will be cheap aswell if the boxes are so cheap, it will need modifying like its goona come in under 2.5k which is about 2k cheaper than most manual conversions go for, defintley food for thought, I personally will only be doing a manual conversion if i go decide to go single for definate Quote Link to comment Share on other sites More sharing options...
Noz Posted July 22, 2015 Share Posted July 22, 2015 http://www.ebay.co.uk/itm/BMW-3-SERIES-E46-3-0-DIESEL-MANUAL-GEARBOX-P-N-1434256-/301412538345?pt=LH_DefaultDomain_3&hash=item462d9657e9 £225 for a E46 3litre gearbox. If these begin to become popular, it'll devalue the v160's for sure as demand would seriously drop. I'm watching this thread with high interest Quote Link to comment Share on other sites More sharing options...
abtin90 Posted July 22, 2015 Share Posted July 22, 2015 Plus propshaft, pedals, clutch slave. Tunnel alterations? When you take all these things into account, plus labor, and include the difference in value between this and a V160/V161 equipped car, I can't see how it makes financial sense. I see what you mean however I'm sure it still works out cheaper than a 6 speed conversion. Furthermore a replacement box is about a tenth of the price of a v160. Whilst the v160's are strong there are members who have broken them. With a BMW box you could buy a few spare while their cheap and not worry too much should it ever fail. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted July 22, 2015 Share Posted July 22, 2015 I see what you mean however I'm sure it still works out cheaper than a 6 speed conversion. Furthermore a replacement box is about a tenth of the price of a v160. Whilst the v160's are strong there are members who have broken them. With a BMW box you could buy a few spare while their cheap and not worry too much should it ever fail. Yes, the only advantage IMO is the cheaper replacement boxes. But Most people with V160's haven't had any issues at all. Their reputation for being bombproof is deserved. Quote Link to comment Share on other sites More sharing options...
s1984 Posted July 22, 2015 Share Posted July 22, 2015 But the problem is that you can´t use the ABC-Kit for the GS6-53DZ gearboxes. The pilot bearing is in the input shaft and not on the flywheel like normal. And the 53DZ is the strongest box from BMW. Quote Link to comment Share on other sites More sharing options...
HadeS Posted July 30, 2015 Author Share Posted July 30, 2015 No updates as yet I'm affraid :/ If all go smooth I'll put gearbox in during the weekend. Quote Link to comment Share on other sites More sharing options...
Jkpgt96 Posted October 15, 2015 Share Posted October 15, 2015 But the problem is that you can´t use the ABC-Kit for the GS6-53DZ gearboxes. The pilot bearing is in the input shaft and not on the flywheel like normal. And the 53DZ is the strongest box from BMW. Actually, some of these had the spigot bearing in the flywheel, not all of them were in the input shaft. I think it is the earlier e60/61 models that still used a flywheel mounted bearing from what I can see. Quote Link to comment Share on other sites More sharing options...
jonny mac Posted March 12, 2017 Share Posted March 12, 2017 hey, I'm looking to use this box on my supra now, do you know if the tunnel accepts the box with a 20mm spacer plate on the back of the 2j engine block in a mkiv? I don't want to bash out my tunnel with a hammer as that's rough I'm more than capable to have the prop made, gearbox mount made, shifter rear mount made etc, just curious about actual box fitment in the chassis I'm planning to use the GS6-53DZ 6 speed with a stock bmw sachs clutch for daily use just now then eventually move onto the pmc kit with triple plate tilton clutch kit when I fit my gte engine Quote Link to comment Share on other sites More sharing options...
