Jellybean Posted April 6, 2015 Share Posted April 6, 2015 Was told it is common problem for the CAM, FRONT SUSPENSION CAMBER ADJUSTER to come out of alignment after some wear N tear on the road, it is best to tac weld it , once it is set? Any truth to this? Link to comment Share on other sites More sharing options...
np89 Posted April 6, 2015 Share Posted April 6, 2015 you'd be better building up the worn areas with weld and grinding it back rather than permanently locking your alignment. im sure it is designed to have some give in it while driving Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 7, 2015 Share Posted April 7, 2015 If they are torqued up properly they don't move. Link to comment Share on other sites More sharing options...
