simbasupra Posted April 5, 2015 Share Posted April 5, 2015 Hi guys. My right hand instrument panel isnt working. It is the one with engine light, oil lights and trc. It used to flicker on if I tapped the unit but its now constantly off. Ive read this is likely to be a dry solder issue. Is there a guide on here/pictures? Thanks Quote Link to comment Share on other sites More sharing options...
simbasupra Posted April 7, 2015 Author Share Posted April 7, 2015 has now come back on, but want to fix this if someone has a guide? Quote Link to comment Share on other sites More sharing options...
trebor69 Posted April 7, 2015 Share Posted April 7, 2015 Don't need a guide it's easy, just refresh the solder on the circuit board with an iron (a soldering iron). Quote Link to comment Share on other sites More sharing options...
Dave Posted April 7, 2015 Share Posted April 7, 2015 Mine did this and heckler re soldered the board Quote Link to comment Share on other sites More sharing options...
mac79 Posted April 10, 2015 Share Posted April 10, 2015 As above it just needs to be re soldered Quote Link to comment Share on other sites More sharing options...
Thorin Posted April 10, 2015 Share Posted April 10, 2015 If it's not working, give it a smack until it does. Worked for me! (but yes dry solder joints) Quote Link to comment Share on other sites More sharing options...
ATB Posted April 10, 2015 Share Posted April 10, 2015 Had the same issue, and a re-solder on the joints did the trick Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted April 10, 2015 Share Posted April 10, 2015 Stuck record I know but use the search. There are countless dry joint solder threads with photographs and guides. I did one over ten years ago!! Quote Link to comment Share on other sites More sharing options...
Bayden_uk Posted April 21, 2015 Share Posted April 21, 2015 If you don't manage to do it feel free to send it to me and I'll sort it for you buddy Quote Link to comment Share on other sites More sharing options...
