syvec help
haz182
im trying to get a log of my syves after a short run to send to lee, im completely new to this, ive downloaded the software onto my pc.. plug it into the syvecs, can someone give me a step by step from getting a log from it (as simple as pos!)? i have been on the forum and watched the videos, is alot to take in. i seem to be only able to get a page like this saved
i go to s/view, logbook per run, click the lastest one and get this.
DEVICE : S6 #536
IDENTITY : GENERIC
BOOT CODE : 1.4
MAIN CODE : 1.28.1
BOXSTATE : MainCode
LAST RESET CAUSE : 5
CODE RETURN CAUSE : 0
LAST PROGRAM TIME : Wed Jan 15 15:16:23 2014
BOOT CODE CREATION TIME : Fri Mar 23 14:21:42 2012
MAIN CODE CREATION TIME : Wed Apr 11 12:46:13 2012
SN PROGRAM TIME : Thu Jun 21 07:41:23 2012
ROOT ID PROGRAM TIME : Thu Jun 21 08:15:50 2012
USER ID PROGRAM TIME : Thu Jun 21 08:16:19 2012
CODE PROGRAM TIME : Thu Jun 21 08:16:27 2012
CALIBRATION PROGRAM TIME : Wed Jan 15 15:16:23 2014
BOOT CODE PROGRAM TIME : UNKNOWN
PRE BOOT CODE CREATION TIME : UNKNOWN
PRE BOOT CODE PROGRAM TIME : UNKNOWN
Solaris S6
Board level : 6
Boot code : 1.4
FPGA : 2.19
Mod : S40
Serial number : 536
Root id : GENERIC
Main code : 1.28.1
ECU off time : 04/04/2015@13:59:23
ECU time now : 04/04/2015@13:59:49
Feat : T
Stack datastream
SYNC : 0->TURN
SYNC : TURN->360
MODE : STOP->PREINJECT
MODE : PREINJECT->CRANK
MODE : CRANK->RUN
SYNC : 360->720
im sure im just being stupid/missing something!
the issue is it just bogs down just as it should come onto boost. can hear the turbos spool up, but just dosent want to boost, feels hesitant and revs go up and down 2700-3000 around the rev it should come on, is a atuo, dose this when you kick down into 2 too. until you come of the pedal. ive had a look for split pipes/lose pipes etc. any help would be great, was running perfect the other day, then started it up today and this has happened. many thanks to any help. Harry
Guest Budz86
Just in case anyone needs to know how to pull a log , do the following :)
Open Sdata
Device - connect - hit enter when the small window pops up; top right corner of the screen will now show connected.
Device - autoread
Enter comment in the comments box so you know which log it is - OK (F10)
File - view latest data in Sview (this opens in another window and displays the data)
File - save as
Locate file and send as an email attachment.
Edited by Budz86 (see edit history)
Too complicated... Just go into Sdata and hit Device and read data. After that several small windows appear where you click ok, yes, yes, clear and the log will be saved in the syvecs folder in downloaded Data(maybe in a sub folder). Locate the log files(.sd ending) and send them :)
