theredone Posted April 3, 2015 Share Posted April 3, 2015 What is needed for a r154 conversion and rough price for the lot I'm currently using a w58 and would any parts I currently have work with a r154 Quote Link to comment Share on other sites More sharing options...
garethr Posted April 3, 2015 Share Posted April 3, 2015 (edited) Off the top of my head... -- R154 gearbox -- 1JZ bellhousing if the gearbox wasn't originally on a 1JZ (Toyota or aftermarket) -- 1JZ-GTE flywheel (Toyota or aftermarket) -- new flywheel bolts (Toyota or aftermarket e.g. ARP) -- flywheel bolt locking ring -- pilot bearing (6201-2RS IIRC, either Toyota or decent quality from a bearing supplier/eBay) -- 1JZ-GTE or 7M-GTE clutch kit (uprated necessary for a 2JZ-GTE?) -- clutch release bearing if not in the clutch kit -- clutch cover bolts if not in the clutch kit -- clutch release bearing hub and various circlips, shims, and washers if not with the 'box (from Toyota, or Driftmotion sell a kit) - replace the washers and circlips regardless -- rear main seal (probably worth replacing it when the 'box is out) -- gear shift extension if the gearbox is from a Mk3 Supra -- gearbox mount? -- prop shaft (not sure if you can use Toyota parts or if a custom prop is needed) http://www.mk3supra.org/topic/596-guide-fitting-a-clutch-on-the-7mgte-r154/ Edited April 3, 2015 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
