TWIN TURBO to SINGLE TURBO HELP
Guest TimothyW1994
Guest TimothyW1994
Hi guys, I currently own a 93' Twin Turbo Supra.
I'm considering converting it to a SINGLE TURBO.
Just wondering what are all the parts that are needed to convert to a single turbo ? I'm sure it's not as simple as just swapping the turbos.
I take it you've not done a search? There's hundreds of threads out there that will give you an idea.
First of all how much power do you have in mind after the conversion? Also the gearbox will limit your choices of setup depending on what you have.
In fact is this thread even for real? Seems like you can't put the effort in to properly explain what exactly you want. I'm out.
There are many threads about what parts is needed.
Manifold
Turbo
Downpipe
Screamer pipe
Wastegate
Turbo blanket
Oil Feeds lines
ECU
Injectors
Clutch if it is a manual
Fuel Pump
Might be a few other parts needed, but always have spare cash stored away. There is always something that needs doing when planning a build.
