Samurai 20V Posted April 2, 2015 Share Posted April 2, 2015 Hi chaps.. Need some info.. EPC for the J spec TT6 lists two ecu's for a pre facelift non-VVTi. 89661 COMPUTER, ENGINE CONTROL 89661-14501 (10/1993 - 04/1996) 89661-14770 (05/1996 - 08/1997) Does anybody know if they are interchangeable? I have both, my car is a 1994 so stock is 89661-14501. The 89661-14770 has the same connector but when I connected it to my car it throws an 02 sensor error, car runs lean on idle. On boost it drives fine. Any info will be helpful. Thanks. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted April 3, 2015 Author Share Posted April 3, 2015 Guys, It seems the (05/1996 - 08/1997) ECU is OBDII... The Yanks on Supraforums swap them over with some mods to get rid of the lean spot on the changeover.. Can anyone confirm this? Quote Link to comment Share on other sites More sharing options...
mr_maj Posted January 12, 2016 Share Posted January 12, 2016 Hi mate did you find out the differences between the 2 ecus? Im looking for the one ending 14770 and have been offered a 14501 This is for a facelift model so ideally I need the 14770 Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted January 12, 2016 Author Share Posted January 12, 2016 Hi mate did you find out the differences between the 2 ecus? Im looking for the one ending 14770 and have been offered a 14501 This is for a facelift model so ideally I need the 14770 Hey mate.. I found the circuit diagrams, they seem the same.. I guess the mapping is different.. My car takes the 14501, I have a Mines 14770, its working fine, with the exception of the O2 sensor heater circuit error it always it had.. If its cheap enough, it may be worth a shot. Quote Link to comment Share on other sites More sharing options...
