Guest lloydy Posted April 1, 2015 Share Posted April 1, 2015 basically i went away for a while, and the battery went flat, i recharged the battery and the car starts up fine, however the indicators flash approx 31/32 times intermittently, and i cant figure out how to correct this, it was fine before the battery died, and i dont know how to stop the indicators going off, anyone shed some light on this? thanks Quote Link to comment Share on other sites More sharing options...
Scott Posted April 1, 2015 Share Posted April 1, 2015 Do you have an alarm system? Quote Link to comment Share on other sites More sharing options...
Tyson Posted April 1, 2015 Share Posted April 1, 2015 Do you have an alarm system? This. When my battery went flat my alarm went a bit wappy until I reset it. Quote Link to comment Share on other sites More sharing options...
Virus Posted April 1, 2015 Share Posted April 1, 2015 Jup, had the same issue Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 1, 2015 Share Posted April 1, 2015 The alarm sounder battery is probably near flat, most charge up when the car is running, should sort itself out when used a bit. Quote Link to comment Share on other sites More sharing options...
Guest lloydy Posted April 1, 2015 Share Posted April 1, 2015 Yeh i have a meta m99/m36t fitted, although the previous owner said he turned it off with the master key. Fortunately after running the car for abit it seems to have sorted its self out, so hopefully it did just need to charge up with the car running. On a side note i havent been able to find where this master key goes to turn the alarm system back on, there is no key hole on the main alarm ecu, so i presume there is a key barrel somewhere else in the car but i havent been able to find it anyone able to chip in with any advice as to where it might be hiding haha. cheers lloydy Quote Link to comment Share on other sites More sharing options...
