Project Blitz Posted March 31, 2015 Share Posted March 31, 2015 Hi all - currently got Brembo F40 Calipers and need to replace the brake discs and Pads. I have had a quick measure up and the Discs are around 330/332mm mark Planning to upgrade the whole lot next year to the F50 or similar with larger discs... but for now i'm after fast road set up. can someone recommend some discs and pads that I should be looking at that will be ok for fast road. Quote Link to comment Share on other sites More sharing options...
mattdavies Posted March 31, 2015 Share Posted March 31, 2015 Email Chris Wilson as he has a some very good fast roads pads and can help with Disc selection Quote Link to comment Share on other sites More sharing options...
bignum Posted March 31, 2015 Share Posted March 31, 2015 Pretty sure the f40/50 is the same caliper, ive gone for stoptech rotors as they are cheaper than brembo but need to be machined down to fit the brembo hats, pads as said chris wilson will be fine, good price too, Also if you wanted to fit larger discs you`d just need the larger bracket adapters afaik. Quote Link to comment Share on other sites More sharing options...
Project Blitz Posted March 31, 2015 Author Share Posted March 31, 2015 How much are the stop tech? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 1, 2015 Share Posted April 1, 2015 I would need a disc and bell to see if I can find something suitable. To be honest if you are set on changing set up do it now, unless a cheap off the shelf disc is available machining a different disc to fit, or maybe making new bells will be costly. Pads are usually ex stock. Quote Link to comment Share on other sites More sharing options...
bignum Posted April 1, 2015 Share Posted April 1, 2015 Speak to Lee srd re discs, circa £400 iirc. Quote Link to comment Share on other sites More sharing options...
