Guest haydon Posted March 30, 2015 Share Posted March 30, 2015 What code is this guys Quote Link to comment Share on other sites More sharing options...
Scooter Posted March 30, 2015 Share Posted March 30, 2015 Looks like 34 but then there is the start of another code forty something but the video stops... Quote Link to comment Share on other sites More sharing options...
Guest haydon Posted March 30, 2015 Share Posted March 30, 2015 If it helps engine goes into limp mode when on hard boost for a long time of if been trashing it for 5 mins or so and then putting it under load Quote Link to comment Share on other sites More sharing options...
Guest haydon Posted March 30, 2015 Share Posted March 30, 2015 Other code is 42. So 34 and 42 what are they how can they be fixed? Quote Link to comment Share on other sites More sharing options...
Stevo Posted March 30, 2015 Share Posted March 30, 2015 Just off the top of my head, I think 42 is the speed sensor code. Do a search on here and there is a great document that tells you what all the codes mean. Quote Link to comment Share on other sites More sharing options...
Stevo Posted March 30, 2015 Share Posted March 30, 2015 Here you go mate, have a read of this: http://www.mkivsupra.net/vbb/showthread.php?35920-How-To-Check-the-diagnostics-codes I was right about 42, it's the no. 1 speed sensor. Hope this helps get it sorted. Quote Link to comment Share on other sites More sharing options...
mattdavies Posted March 31, 2015 Share Posted March 31, 2015 Here you go mate, have a read of this: http://www.mkivsupra.net/vbb/showthread.php?35920-How-To-Check-the-diagnostics-codes I was right about 42, it's the no. 1 speed sensor. Hope this helps get it sorted. If you search Pink Wire Mod tis will help you get rid of this ( Unless I have confused my Mods ) Quote Link to comment Share on other sites More sharing options...
mattdavies Posted March 31, 2015 Share Posted March 31, 2015 Duplicate Post Quote Link to comment Share on other sites More sharing options...
Guest haydon Posted March 31, 2015 Share Posted March 31, 2015 Dident think the UK spec had a speed limiter Quote Link to comment Share on other sites More sharing options...
Guest haydon Posted March 31, 2015 Share Posted March 31, 2015 Bump* Quote Link to comment Share on other sites More sharing options...
