AlexJames Posted March 30, 2015 Share Posted March 30, 2015 My Celica tailgate is only a little lighter than the Supra tailgate... Anyone roughly know the force needed to lift it? 100N 200N ? Link to comment Share on other sites More sharing options...
Digsy Posted March 30, 2015 Share Posted March 30, 2015 No idea, but I know that there are two types of (genuine) gas springs for the Supra: One for cars fitted with a rear wing and those without. Link to comment Share on other sites More sharing options...
P_Bazz Posted March 30, 2015 Share Posted March 30, 2015 100N equals roughly 10kgs of force, of course you want to exceed the actual weight of the tailgate in order to lift it but you can measure it relatively easy by pushing up at the pivot points with a scale and a stick. Link to comment Share on other sites More sharing options...
Digsy Posted March 30, 2015 Share Posted March 30, 2015 100N equals roughly 10kgs of force, of course you want to exceed the actual weight of the tailgate in order to lift it but you can measure it relatively easy by pushing up at the pivot points with a scale and a stick. The gas strut moves through quite a large angle as the tailgate opens. You would have to push on your stick at the same angle as the gas struts when the hatch is closed and again at the angle when the hatch is open to see which gives the greater figure (probably when the hatch is closed). Link to comment Share on other sites More sharing options...
AlexJames Posted April 2, 2015 Author Share Posted April 2, 2015 Good points... I guess the next question is then.. how much does a tailgate weigh? Link to comment Share on other sites More sharing options...
